Question about Janome 4623 Mechanical Sewing Machine
The timing is off and needs to be adjusted. - Janome 4623 Mechanical Sewing Machine
I need to adjust the hook timing on my euro pro 361 and need to know how to adjust the needle bar
Search the internet for:
"sewing machine timing"
there are many web sites and videos available.
Oct 23, 2016 | Sewing Machines
Adjust the timing
May I ask WHY you want to adjust the hook timing? What makes you think that you need to do so?
Oct 17, 2014 | Singer Curvy 8770 Electronic Sewing...
Singer sewing machine timing adjustment
This is an often asked question. Also, you didn't mention which model you have. Regardless, I always answer that with another question, and that is--why do you think the timing needs adjusting?
Aug 31, 2014 | Singer Sewing Machines
Adjust timing on singer
what timing are you talking about? If is needle timing, remove the left cover of the machine and try adjusting the timing from there . If the problem is more complex, you will have to remove the bottom of the machine. It's not difficult but, if you need any help, I will guide you step by step.
Aug 04, 2014 | Singer 4411 Sewing Machine
Singer serger timing
.... IF the timing is out, it REALLY is a job for a Techie. There are too many adjustments that need to be spot on. Get it wrong and you can cause damage to your machine :)
Apr 22, 2014 | Baby Lock Eclipse Serger
My machine needs timing adjusted
a sewing machine repair shop is the best place to have the timing fixed, because they have the proper tool to do the adjustments needed.
Aug 22, 2013 | Sewing Machines
Singer7462 timing adjustment
try these sites
youtube
fixsewingmachine.com
Mar 04, 2012 | Singer 7462 Mechanical Sewing Machine
How to check timing on pe180d embroidery machine
In case of adjusting sewing machine timing, there are twomain parts that you should follow.To adjust the hook needle timing on the rotary hook, first,remove the bobbin, bobbin carrier, and covers so you can see the movement ofthe hook. This may involve removing the needle plate for top loadingassemblies, or removing the hook cap from the front of the machine. Itoften requires the removal of the lower covers to reach the componentparts. Adjust as needed when doing sewing machine repair.Set the machine to a straight stitch at the defaultposition. Different models have different default positions including themost common far left and center positions. If no problems are perceivedin needle bar positioning, the default position will suffice. If thereare needle bar position issues, these need to be adjusted prior to adjustingthe timing. Follow proper sewing machine repair procedures.Rotate the hand wheel toward youuntil you see the needle reach its lowest position and begin its rise. Now lookfor the point of the hook as you continue rotating the hand wheel. Thepoint of the hook should strike inside the needle scarf above the needleby about 0.5mm. Sewing machine repair is vital for smooth operations.Check to see if the hook fails topick up the thread. Double check the needle bar positioning including thehook needle spacing. If these are appropriate and the point of the needlestill fails to pick up the loop thread, proceed to adjust the timing of thehook. Maintain regular sewing machine repair. Look for the lower drivemechanism. It may be a lower shaft with gears on either end. If this isthe case, look to the right end of the shaft for a gear with adjusting setscrews. Loosen and manually adjust the position of the hook. Tightly hold thehand wheel while turning the drive shaft to set the proper position. Retighten adjusting screws. Some models have timing beltsthat control the timing of the sewing machine. Look for a belt connectedon each with to drive gears. Look for work cogs on the belt. Inmost cases, you can reset the timing belt, without replacing it. If,however, the belt requires replacement you will need to do so. Loosen the drive mechanism on the right side to free the movement of the belt.Manually adjust the position of the hook to the needle and re-tighten set screws. This knowledge is vital for effective sewing machine repair.Once the timing has been reset,conduct thorough test sewing on the sewing machine to make sure everything isworking properly.Hope this will help you. Good Luck.
Oct 16, 2011 | Brother Disney PE-180D Computerized Sewing...
Timing the needle
That isn't the timing. If the hook is hitting the needle the hook is too far left - or close to the needle. It's adjustable by loosening the set screw at the base of the hook and by gently tapping the hook away from the needle. You want the hook to be close enough to the needle to pick up the thread loop that's formed just as the needle bar is rising.
Aug 29, 2009 | Sewing Machines
Janome 4623 Mechanical Sewing Machine Logo
24 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
