Question about Dometic RM2452 Refrigerator
RM 2453 Frig. trips the GFI Circuit and does not power up on AC mode.
    Top Expert:
  • Dometic Master
  • 8,143 Answers
Shorted heater element replace
Posted on May 27, 2016
3 Suggested Answers
  • 905 Answers
SOURCE: I have a 2004 Coleman
Hello Barry,
More than likely, your heating element has become shorted to its case, thereby allowing current to flow outside of the neutral, tripping the GFI. If you have a multimeter, you can measure the resistance of the heater itself (AC heater should be 125 ohms, +/-10%). There should not be any continuity between each of the heater wires to the case of the heater itself.
Service Manual
bryantrv.com/docs2/docs/rm2100.pdf
Owners Manual
bryantrv.com/docs2/docs/rm2193.pdf
Posted on Aug 18, 2010
reyjoshua07
  • 1157 Answers
SOURCE: Have a Dometic 2452/2453 fridge. when in gas mode
Hi jjk894,
If it does not cool on either gas or electricity but is getting hot at the rear of the unit chances are that the cooling unit will need factory repair or replacing. There are only two main failures with gas RV refrigerators.
1 The RV refrigerator is run unleveled causing the cooling unit boiler to overhead, block and crack.
2 The RV refrigerator cooling unit's steel tubing rusts and the ammonia/hydrogen gas leaks out.
Gas RV refrigerators do not operate the same way as other refrigerator types. They are charged with four types of chemicals and this mixture must be exact for the unit to work properly. The four chemicals of the charge are.
1. Water
2. Ammonia Gas
3. Hydrogen Gas
4. Rust Inhibitor powder
Boiler blocks or cracks - If the refrigerator is run while not leveled for an extended period, the cooling unit water will not flow into the boiler. The boiler as a result gets excessively hot and can bake the rust inhibitor. This will in-turn block the small 1/4" tube in the boiler and all flow will stop. If the refrigerator is kept running under these circumstances the boiler tube will get so hot that it will crack open. If this happens a yellow powder around the burner area may be visible indicating that the cooling units rust inhibitor is leaking.
Leaks - When a unit rusts and leaks as a result, the ammonia gas is lost first. You can sometimes smell the ammonia gas. However when the door is opened or if the leak is small there can be little or no smell. Under these circumstances there could be a boiling sound at the back of the refrigerator. This means the hydrogen gas has also leaked out and the water is now boiling. Ammonia smells or large gurgling sounds from the refrigerator are indicators that the refrigerator cooling unit is leaking.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 23, 2011
REFRIGERATOR HAS STOPPED WORKING , NOTHING RUNS, NO LIGHTS NOTHING
If everything is dead the first thing you have to establish is that the unit is receiving electrical power. It is far fetched for every component to go bad at the same time!!!!!!
Jun 25, 2015 | LG LSC27910ST Side by Side Refrigerator,...
When activated, the thermostat stays on for about 45 sec. and then kicks out indicating a gfi problem . . . this seems far too sensitive . . . can I override this in some manner?? Thanks, Wayne
You can replace the wall outlet with a GFI type and cut the ac cord end off and install a basic 3 prong for 120 volt system. AC unit controls don't like ground faults and should be corrected. The cord gfi may be going out.
Apr 03, 2015 | Heating & Cooling
Frig is intermittently tripping GFI outlet.
To be short, the only thing in the machine that really has the capability of causing that is the compressor. Its got a floating short in and when it makes contact it trips the outlet/breaker. Check for any exposed wires just to be sure but I'm pretty certain that the compressor is the culprit and either it or the machine needs to be replaced.
Apr 21, 2012 | Kenmore Refrigerators
Purchase new 32'' tv 2-day ago, will not work in a GFI plug outlet trips GFI each time you reset, is there something wrong with unit? works fine in a non GFI outlet
Good News!!! GFI outlets are made to trip when a large amount of power is pulled through them. A GFI is basically a small circuit breaker.Your television set is probably just pulling more amperage than the GFI is rated to handle. That means the GFI is working properly And so is the TV!
May 05, 2011 | Televison & Video
Older Kenmore model 110.82673110 washing machine keeps tripping the GFI. Replaced GFI but problem persists. How can I fix this?
i would install a regular outlet... and if the circuit breaker blows. then their is a direct short within the washer .i never heard of GFI being used on a washer ..remove it.. their may be other outlets on this circuit also that can adding to it tripping. like frig.. find out what is on that circuit by shutting off the breaker for washer see what else goes off...
Aug 24, 2010 | Kenmore Washing Machines
I have a 2004 Coleman Westlake tent trailer and my RM2193 frig blows the main GFI (inside the trailer) everytime I switch to AC power. Frig works under DC and propane. What can I do to troubleshoot this...
Hello Barry,
Service Manual
Owners Manual
Aug 18, 2010 | Dometic RM2193 Compact Refrigerator With...
I have a question on Coleman AC
First of all, an extension cord and GFI receptacle to run an AC unit will almost always blow either GFI or circuit breaker or both due to large current draw from AC unit. If an extension cord needs to be used, keep it as short as possible, and use the heavier gauge that is approved for AC use. What happens when you use an extension cord, is the voltage drop that will happen by the time the AC gets power. With any voltage drop, the amperage draw increases, so a 15 amp circuit breaker will most likely trip. Nowadays, all AC units are wired with a minimum 12 gauge wire rated for 20 amps.
You say nothing is happening now, is that to say that the fan only mode doesn't work on the AC unit either?
Apr 26, 2010 | Dometic Rooftop RV Air Conditioner
GFI Trips when pluged in.
Hi, Are you unplugging the big black hard wire that goes under the evaporator coil in the freezer. If so, that is the defrost heater and it has gone bad. Please let me know if I can explain anything further.
Thanks
Vic
May 20, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Feb 03, 2009 | Dometic RM2652 Refrigerator
Ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
Sep 07, 2006 | Whirlpool AD50USL Dehumidifier
Dometic RM2452 Refrigerator Logo
23 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
