Question about Hitachi C3390FSP 33" TV
Horizonal problem If I move my tv or just turn it around to hook something up it disorts my picture.It has horizonal lines on whole screen.Sometimes I will unplug for a few days and it will work.But this gets really aggravating.Anybody have any advice?
  • 1,694 Answers
Practice visual acuity technique! Examine chassis,solder any/all bad connects,re-assemble,try again.If that does not do it,you might have a small break in pcb==gently flex board,try to isolate area.Above all else,do no harm!!
Posted on Sep 26, 2007
Two inch horizonal (black and white) line move from botton of screen slowly up the screen. Each line is about 24 inches apart. Also at times the picture will become dark with muted our of focus images. ...
The best way to determine what is at fault is to disconnect the Denon tuner and run the signal straight to the TV. If the problem goes away, the Denon is at fault.
May 17, 2011 | Hitachi 51F500 51" Rear Projection...
I purchased the tv in 2007 and it has been great until now. The picture went out a few months ago around the time we had all of our plug outlets replaced by an electrician. I initially had audio but no...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 16, 2017 | Panasonic TH58PX600U 58 in. Plasma HDTV
When i turned the tv on, i heard like a "click" noise, and the, there was no picture, only a horizontal light line
Sounds like one of the components and/or screen is going or gone,. the "event horizon" of screen deaths, not good. sounds like this one may need to go into the repair shop,....may only be a small component and not whole screen. best to get estimate and call repair shop with issue first...
Oct 17, 2010 | GE 25GT516 TV
Screen flickering, dim, lines moving up the screen
If it was new in 2006, it probably is not worth repairing.
Jan 06, 2018 | Toshiba 72HM195 72" HDTV
My older Toshiba TV is showing horizonal lines on upper screen.
maybe dust in the back of set try giving it a hoover out but unplug first
Mar 19, 2009 | Toshiba Televison & Video
All my blacks are red
Something wrong with T-Con Board or connector problem between T-con & Main(LVDS)
Jan 27, 2009 | Samsung LN40A650A LCD TV
Intense white & coloured horizontal line on black background on startup
I wouldn't attempt as the capacitors on a tv store around 25000 volts this is more than enough to kill you and they keep there charge even when the tv is off. Either take it to a repair shop or put that money towards buying a new tv - Do not even attempt to open the tv. (It sounds like maybe a tube has gone or the electromagnet that makes the beam move vertically is gone.
Sep 03, 2008 | Televison & Video
When u turn it on the screen goes blurry and disorted or it wont even display on the screen
This could mainly be that your scart lead could be loose at the tv end or it is loose at the console end, also see of the disc is not smudged or scracth sometimes this is a cause, it may be your tv is broken instead of the console, if it is a gameboy you may have broke a pixel line.
Jul 04, 2008 | Video Game Consoles & Games
No picture or just one line across screen on hitachi ultravision rearproj.
Could be a loose connection on the printed circuit board in the Vertical deflection circuit.
You would have to have a qualified technician to repair this problem.
A intermittent connection in the circuit described can cause a horizonal line across the screen.
You have to be careful and not leave the TV on for a period of time with a bright line, as it can actually burn a line on the CRT screens, which is permanent.
Mar 24, 2008 | Televison & Video
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
Hitachi C3390FSP 33" TV Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
