Question about Leviton 5611-2ISP Grounded Switch
Trying to install a 5611 beside a 5613 illuminated rocker switch. The 5613 lights up but the 5611 won't.
3 Suggested Answers
SOURCE: I replaced my old 3way
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Posted on Nov 14, 2010
  • 140 Answers
Sounds as if you have a bad illuminated switch. The little LED or light inside the switch is itself possibly bad. Return it to the store and get a different one.
Posted on Jul 15, 2015
Dome light will not come on when doors are open
Have you pressed the dome light cut-off switch by mistake ? Look for a tab rocker switch beside the headlight switch on the daash that has your fog lights on one flap and dome on the other.. open the door and press the switch both ways... maybe your just in "no-dome" mode ...
Feb 12, 2015 | 2010 Chevrolet Tahoe
I am trying to illuminate a 6 pin rocker switch the light is on but in the off position
You have your ground and positive reversed. Locate the ground and positive wires and change the positions on the switch.
Dec 08, 2011 | Cars & Trucks
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
I am installing a Leviton Photoelectric switch and have two wines in the box Black which has power when tested and White that shows no power. The switch has three wires Black, Yellow and Red. What is the...
Something doesn't sound right here. The 5611 series products list themselves as being single-pole products with screw terminals - and you're describing what sounds like a three-way device with wire leads. It almost sounds like the wrong product was put in the box. Regardless...
First of all, I want to make sure that we're replacing a light switch. I am assuming that the two wires are the hot feed, and the switched-hot return to the light fixture. I dont' want to rule out the posssibliity that if, say, a receptacle used to occupy this box, the white white may actually be a neutral - in which case, installing a switch here will cause a short.
Assuming for the time being that it is a standard 3-way switch, of the three wires on the unit, one should be listed as the "common", and the other two as "travellers" - connect the common to one of the two house wires coming from the wall, connect one of the travellers to the other house wire, and place a wire nut on the remaining traveller (unused). If you can't figure out which wire is which, just guess and if it doesn't work, try a different wire combimation - there's only three possible ways to wire it and only one of them won't work.
Oct 17, 2010 | Leviton 104-05611-2WS 15A Decora Single...
Installing a combination switch
The three way will have more connections, whereas the Single Pole, should only have a few contacts the three way will have more.
May 27, 2010 | Leviton 002-1754-W Dual Rocker Switches
The light in my lighted switch has stopped working. What could be wrong?
if switch still works, the little diode in switsh is burnt out. easier to just replace switch
Nov 17, 2009 | Leviton 5611-2ISP Grounded Switch
Leviton 5611-2ISP Grounded Switch Logo
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
