Question about Panasonic KV-S1025C
Error code 3040 for Panasonic KV-S1025C Scanner
  • 16 Answers
SOURCE: KV-S1025C
If you still have the CD that came with your scanner, put it in and you should be able to install the Panasonic Scanner User Utility. The utility has the buttons to allow you to clear the counter(s). If you no longer have the CD, then this link may help: http://panasonic.co.jp/pcc/products/en/scanner/downl_e.htm#USERUTY
Posted on Dec 02, 2008
  • 16 Answers
SOURCE: Scanner No Paper Detected Error
There is a narrow FFC cable that connects the sensors between the hoppper assembly and the main scanner unit that may be loose. Check both ends. This cable can also develop small fractures over time. These fractures can cause the sensors to not be noticed by the scanner or give false info. The cable may need to be replaced.
Posted on Sep 08, 2009
  • 1196 Answers
SOURCE: We have a Panasonic kv-s2055l scanner receiving a
You will need to reset the printer, Hold down the reset and stop button for 15 seconds to reset the printer. Power off the printer after this and allow few minutes to pass before you power on back, if the problm still persist after this, repeat the sequence again.
Posted on Dec 08, 2010
SOURCE: panasonic scanner kv-s3065c error code
F40-30000000 Solution You have to replace under the hopper cable part number PJJEC3437Z and board part number PPB747ADF25H from www.partstore.com this will take about 2 hours to do because of the covers you have to take off.
Posted on Jul 26, 2011
technical114
  • 1851 Answers
SOURCE: just switched to Win 7
As you can see at this official link the driver provided here is Windows 7 compatible. In case you have a proble take a look at this "how to" link.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 04, 2011
Software issue with desktop scanner USB
Have you gone to Panasonics support site and researched tis code.
May 25, 2016 | Panasonic KV-S1025C
Driver
Try doing Apple update as most of the older device drivers are not available.
Regards,
Sean
Jun 05, 2013 | Panasonic KV-S1025C
Recently had windows seven installed after a burn out on old hard drive not compatible with my scanner kv-s1025c any help please
Hello, basically, that's the curse of Windows 7. Unless the manufacturer of the peripherals is prepared to support the older stuff by writing new drivers for it, (and, of course, he won't make any money from that!) there's nothing we can do except shell out for new stuff that IS supported under W7. Personally, I'm sticking to XP Pro, as it's never let me down and there's bags of life in it yet. Regards, nicam49
Sep 06, 2011 | Panasonic KV-S1025C
I'm getting an "F62-52000000" error
F62 error is a problem with the lamp gain on the rear page camera .
Usually removing the camera & cleaning the optics will sort it out .
The scanner will need a good service & shading adjustment as well .
Only attempt this work if you are familiar with CCD Devices & care, as damage through mistakes can be very expensive .
AP Support Solutions
Aug 05, 2011 | Panasonic KV-S1025C
Scanning half the page.
you should reinstall the driver for this scanner and be sure that the top cover doesn't have any heavy things atop it
Mar 30, 2011 | Panasonic KV-S1025C
Our panasonic scanner has a error message that states " place paper in feeder" There is paper in the scanner to be scanned. How do we get rid of this error???
This error occur for some reason, please check each one:
1; ADF document feeder is not closed really and
2; You are put the documents into a wrong place
3; the sensor of the ADR is wrong or is dirty (in this case you need a mechanic)
Please read carefully the ducument below (be care of page 23)
http://office.manualsonline.com/regman/exit/ct?url=aHR0cDovL3NlcnZpY2UudXMucGFuYXNvbmljLmNvbS9PUEVSTUFOUERGL0tWUzEwMjVDLlBERg,,&target=productDoc&idDeviceType=2727&idMfg=1569&idProduct=191533
Rgd,
Sly
Nov 22, 2010 | Panasonic KV-S1025C
The error light on the scanner is flashing but the manual does not say anything about a flashing error light. What is wrong with the scanner?
I am having the same issue. It still scans, but the light will not go out. Did you ever resolve the issue?
Aug 18, 2010 | Panasonic KV-S1025C
How do you reset the counter on a Panasonic KV-S1025C. I have cleaned all of the wheels but can not find how to reset the counter. Many Thanks. Mike.
Click on the Scanner user Utility at the bottom of the pc task bar it is a yellow box it has a button inside to clear the counter
Dec 10, 2009 | Panasonic KV-S1025C
How do you clear the counter button on a panasonic KV-S1025C
Yes, you start at your start menu, then all programs, then panasonic, then scanner tool, then user utility.
Aug 14, 2009 | Panasonic KV-S1025C
KV-S1025C
May 16, 2008 | Panasonic KV-S1025C
Panasonic KV-S1025C Logo
76 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
