Question about Polaroid PDM-0817 Portable DVD Player
Poor Colour images/gray/faded etc...
My portable DVD player is about 4years old, but low usage...perhaps 10 hours per yera?!?!? Well now is presenting the above subject matter. I cheked the troubleshooting manual, and it does not say anithing about this particular problem. It looks like the brightness is adjusted to almost its max, but envn trying to lower brithness the colours are just faded. Can you give me a hint on how to solve this problem and is it feaseable do to so? Thanks.
  • Brdude Sep 27, 2007
    It's been with this problem all summer long. So I don't believe that temperature is an issue for the time being. Thanks!
  • Brdude Sep 30, 2007
    It was good the last time we used. Next time after that the problem was there. Say...if it is the display as you said, how can I fix it? It is repleceable? It is feasiable to replace? Thnaks.
  • 363 Answers
This may not be the solution but its worth a try to asking you. Make sure the player is not too cold. LCD's like to be at a comfortable room temperature. Good luck.
Posted on Sep 26, 2007
  • Anonymous Sep 29, 2007
    Another try, how about the opposite..
    If the display was left open in bright sunshine for a long time then it might be possible the display has been damaged by UV bleaching out the dyes.
    Was it a gradual decline with the picture or was it good one time then suddenly not?
    Regards
  • Anonymous Sep 30, 2007
    Certaintly this excellent player is still supported.
    I would recommend repair at a service centre.
    www.polaroid.com
    A comprimise may be to connect an external monitor or TV to the video output on the unit instead of replacing the display, if that is what the fault is..
    Hope this helps?
SOURCE:
Faded black
Hi Evan Z,
Not quite sure what you mean faded black.
Is the print faded at one side or overall the page?
Now think if it's faded on on seed then it's possible that it could be a build up of toner on the laser head unit. If it's an overall faded page then look for possible poor connections on CRU's.
Check the other working CRU's do they look the same? Don't start turning rollers the opposite way they would normally rotate.
Finally a light overall image can occur when the developer tank has seized up, or a broken drive gear, effectively starving the developing system of fresh replenished toner.
All developer tanks regardless of colour work in the same way, perhaps a slightly different shape as to avoid incorrect fitment.
if in doubt goto the www.xerox.com website and seek more help there.
Good luck.
Sep 01, 2013 | Xerox Phaser 6130 Laser Printer
I am taking a power-point class. I am having some problems coming up with ideas for my final project. It has some requirements. 1) Between 10 and 20 slides (if less than 10 slides, issue 1 point per...
Building a shed is a good idea and supports the validity of the excel sheet, especially if you are listing materials needed, material costs etc.The hyperlinks could be used to move back to key topics such as safety issues. The voice over would be good as an intoduction and as a "recap" at a key stage.
I'd choose a topic you are comfortable with, know quite a bit about and are able to lead people through the subject with confidence. Practice the voice over, a shaky or uncertain voice lowers morale for the presentation. Keep the voice over to a very minimal prescence and that way you will be using it to good effect.
Don't use music as a background noise, it tends to confuse messages. Pick a background that is easy on the eye and avoid the "fancy" templates that are included, a simple muted colour works well, primaries and garish colours really irritate the audience. Avoid Black or White for the same reasons. Blues or Greens are relaxing and creams and other natural colours work well in my experience. (based on doing at least 2 powerpoints a week for 10 years)
The font you use should be leigible, a sans serif like Arial or Helvetica or Gill sans is good. Use effects like drop shadow on type with care and do not overuse.
Do not cram too many bullet points on a slide.
Space out the dynamic content throughout the presentation (ie: let voice, excel sheet and images break up periods of text slides and where possible combine text and image. This helps maintain interest.
Do not be afraid to stop and start the presentation if you want to refocus attention, emphasise a point or merely give your audience an "eye break". Perhaps putting in a blank slide of a different colour at this point is a good idea, or even a slide with the word "Recap" in large letters on it...or similar.
Transitions and effects.. use wisely and in moderation. NEVER use more than 2 effects in a presentation, avoid the spin and other OTT effects, a simple fly in or fade in is much more effective and keep away from any sound effects, it makes the whole thing look clumsy and unprofessional.
You MIGHT want to (if allowed) insert a short video file into the presenatation, always an eye catcher, as long as it is short.
Pictures: Low resolution images that you need to size up will pixellate badly making the tone of the presentation look "chavvy". On a similar note, check spelling and grammar.. I recently gave a presentation to the vice principal without checking it..
Anyway, hope some of that helps, best of luck
Jan 27, 2011 | Microsoft Computers & Internet
The screen is blank and white and the sound works
maybe the set-up of your dvd is pal. try to select auto
May 05, 2009 | Televison & Video
Dvd player is not palying dvd movies but it is paying vcd
get a refund. This fault is a can of worms mate. A road you do not want to go down
Dec 25, 2008 | Sony DVP-PQ1 Portable DVD Player
Power Consumption
If you have a amp probe you can make a test cord by splitting a standard household extension cord. you will want to make sure not to expose any wire in this process then put the probe around one of the wires for testing the one that is attached to the small tab on the cord or the one that gives you a reading.
to answer your question the maximum power usage would be 150 watts with the setup you described. I would guess this would be less depending on the brightness setting of your tv you use ie. super bright more power less bright less power.
on another note if you are concerned with power usage. there are whole house wattmeters available that clamp on the outside of your homes meter outside. it reads the wheel or digital signal the one I bought is wireless and the reciever is programable with your utilities rate to let you know how much money per hour your spending and even has a running total and peak usage stats date time and temp. outside.
Mar 29, 2008 | Televison & Video
DVD works but the screen is black and white
Precorded discs, or copies made on a computer? Other than that, getting service will take a miracle, as the company is out of business...accordianman
Jan 02, 2008 | Cyberhome CH-LDV 700B Portable DVD Player
S-750DD
Not sure if this will help... however an altmeter will allow you to test along your electrics for any faults. You can check at the lights for example and throught the system.
Oct 11, 2007 | Transport Schwinn Rechargeable Portable ...
DVD player producing poor colour image
Go purchase a DVD player cleaner. It will look somewhat like a DVD/CD and will clean the read heads. Often the issues is dirt/dust.
Semper Fi,
Z
Jan 29, 2018 | Televison & Video
Screen B&W only: Same as other poster
Screen works you get a black and white image. The colour stage works you get colour output to TV So my guess is the ribbon connector from motherboard to screen is loose or adrift. Is this something you fell you can fix or 'know a man that can?'
Aug 19, 2007 | Durabrand PDV-705 Portable DVD Player
Polaroid PDM-0817 Portable DVD Player Logo
55 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
