Parts splendide wd2000s
Dryer wont heat
3 Suggested Answers
SOURCE: splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Posted on Dec 21, 2009
  • 403 Answers
SOURCE: hello my splendide wd2000s wont drain or spin and
If the machine senses that there is water still in the tub, it will not release the door. Unplug the machine you should her a click and the door should release itself. should take about a minute. As far as the drain and spin, remove the washer/dryer back and check the drain pump, check that the lint filter is clean and that the drain hose is clear of foreign objects. I have instructions for how to unlock the door when the machine is in a cycle. If you're door lock is continuously giving problems,i can walk you thru the steps to test it, to see if needs to be replaced. Lets start with those solutions first, if they don't work we can go to the next step, which would be to test the drain pump and the door lock, and also to put the machine in diagnostic mode
Posted on Feb 07, 2011
Where to finde front door handle
This is the information taken from the Splendide website. Hope it helps.
Westland Sales - Splendide Service Headquarters in Clackamas, OR Telephone:
Direct Fax:
E-mail:
Hours: 1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
*To help us serve you better, please have the Model & Serial Number of your machine ready when you call. The Serial Number is located on the inside door opening of your machine.
Jul 26, 2014 | Ariston Technologies AWD 121
Hello my splendide wd2000s wont drain or spin and wont release the door lock...what do you think
Feb 07, 2011 | Splendide 2000S Front Load Washer / Dryer
Wont heat to dry
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
fsjgfj
Jan 25, 2010 | Splendide 2000S Vented Washer/Dryer
Splendide 2100 washer/dryer now fails to dry -
Sep 19, 2009 | Splendide 2100 Vented Washer-Dryer
WD200S overfills with water
Sounds like the switch that detects the water level is malfuntioning, this can be caused by one of several reasons.
I assume that the water stops running in if you stop the m/c, if it does not, then you have a faulty water inlet valve, which you would have to replace.
I think you neede to call an engineer.
Hope this helps.
Please leave feedeback.
Dec 07, 2008 | Splendide 2000S Vented Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
