Question about Northern Industrial Tools Northern Industrial Portable Vertical Air Compressor 21-Gallon
Part for a fenwai/model;fw-10 - Northern Industrial Tools Northern Industrial Portable Vertical Air Compressor 21-Gallon
2 Suggested Answers
  • 41 Answers
SOURCE: I am trying to find
You can use a generic replacement , I would check "Drillspot".
Don F
Posted on Sep 09, 2011
I Need drivers for iMac 10 that work with Micronet PHD16072u2f
Hi, seeing that this drive has both USB and FireWire connectors it does not need any drivers. - In fact I have never needed drivers for any external drive in all of my 20+ mac years.
First thing to check is that the drive is powering up. Can you feel it come on and off when you turn the power on and off?Try connecting via the FW or the USB in turn (never together). TYry different cables - there are poor cables of both sorts.
If there is still nothing, try connecting something else to the same connectors of the computer - does it show up?
Sometimes the built-in USB hub can throw a wobbley - as can the FW hub. Resetting the USB hub is normally done by rebooting the computer. Resetting the FW is a little more complicated and varies from Mac to Mac - so check out on the Apple support pages at Apple.com the correct way to do it for your particular Mac.
Mar 26, 2013 | Computers & Internet
Searching for fenwai pressure control fw 10
If your compressor is a piston compressor, try cleaning the check valve which comes from the pressure switch to the tank (it has a little spring and a rubber/plastic valve inside)
Otherwise check to see if it is sucking air in properly, (whilst it is running, remove the air filter, and very quickly put your hand over the air intake to see if it is sucking whilst it is at 20 psi, if not, then it may be that the valves in the head maybe either broken or not seating properly
If it is not a piston compressor, then it maybe the MPV needing some attention
Hope that helps
Aug 22, 2012 | Air Tools & Compressors
I have central pneumatic 21 gal. air compressor. The unloader valve is broke. The power switch is a fenwai model: fw-10. Where can I buy a new unloader valve?
If you should mean the switch that is pressure controlled that turn the compressor on and off- that is a fairly universal replacement piece, As is the power switch itself
If you needed that specific part, your best bet is Harbor Freight tools who owns the Central Pneumatic domain.
Feb 14, 2012 | Air Tools & Compressors
Apparently there is a problem with Beko refrigeration manufactured between 2000/2006. Please confirm model number in question.
From Beko:-
"The BEKO frost free fridge freezer models affected were manufactured between January 2000 and October 2006. These have a serial number that begins with either 00, 01, 02, 03, 04, 05 or 06. and this information can be found on a label inside the fridge. Beko is making a free of charge modification to all affected models, this modification takes approximately 30mins.
Other Beko branded models and all Beko frost free fridge freezers manufactured after this date are unaffected.
Affected model numbers:
    • CA 5411 FFS/FFW/FFX
    • CA 7014 FFX
    • CA 7015 FFW/FFS/FFX
    • CDA 539 FS/FW/FX
    • CDA 543 FS/FW/FX
    • CDA 645 FW
    • CDA 647 FS/FW
    • CDA 648 FS/FW
    • CDA 653 FS/FW/FX
    • CDA 659 FS
    • CDA 751 FS/FX
    • CDA 752 FS/FW/FX
    • CS 460 FF/FFS/FFW/FFSD
    • CS 461 FFW/FFS
    • CSA 4706 FFX
    • CSB 4606 FFSD/FFS/FFW"
If you find that your model is listed above and is in the correct model year range then you need to click here for further guidance. There is also a freephone number, but it's swamped by callers. Even if you get through you will receive exactly the same advice as you would from the website links.
If you want to know more about what the actual problem is, then click here.
Please take a moment to rate my answer.
Jul 06, 2011 | Washing Machines
Wireless portion of d-link di-524 is not working. Flashed with fw ver 1.23 and no avail, flashed to fw 1.05 worked for ten minutes. Help please!
If it worked briefly then stopped, it's probably faulty with a heat sensitive component. Switch it off overnight and see if it works next day. If it fails again after 10 mins, get a new one.
May 16, 2010 | D-Link AirPlus DI-524 Wireless Router
Philips FW 780 v Set Wiring Diagrame
Please will you indicate the problem so that we can go by the present issue. Within the electronics side specify whether it is power side, the drives,or the optical.
Feb 27, 2010 | Audio Players & Recorders
HW reset FW500ME to factory default
press it's back side you find reset button press it for 10 seconds then all settings are reset to defaults.
Jul 16, 2009 | Lanner FW 500 (FW-500) Firewall
Northern Industrial Tools Northern Industrial Portable Vertical Air Compressor 21-Gallon Logo
54 people viewed this question
Top Northern Industrial Tools Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Northern Industrial Tools Air Tool and Compressor Expert? Answer questions, earn points and help others
