Question about Sewing Machines
I have a euro pro x I cant get the upper thread to pick up bobbin thread I have tried everything please help
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Are you holding the end of the top thread whilst trying to pickup the bobbin thread? Put a BRAND NEW needle in - it may look OK, buy the slightest bend will be an issue. Is it the CORRECT needle for you machine? - check your manual. Is the bobbin in the case correctly and feeding out the correct direction? ...... timing may be out
Posted on Oct 19, 2013
4 Suggested Answers
SOURCE: needle will not pick up bobbin threat
I had the exact same problem. The timing is off. You can actually fix this yourself all you need is an allen wrench. If you look at the rod the needle is inserted into and follow it up to about 2 inches below the top of the machine there should be a clamp. use the allan wrench to loosen the clamp and adjust the needle height. I used this website as a guide to getting the timing correct. http://www.sewusa.com/Sewing_Machine_Repair/Repair_Pictures/timing1.gif
now if only I could figure out why my thread keeps getting jammed under the bobbin!
Posted on Feb 22, 2008
SOURCE: needle not picking up bobbin thread
Check the timing.
Posted on Mar 06, 2008
SOURCE: the bobbin thread on sewing machine will not catch
how do you retime
Posted on Aug 13, 2008
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
Needle not picking up bobbin thread how can I fix this ?
Try installing a brand new needle. Sometimes a bent/damaged needle will not pick up the bobbin thread.
Check that the bobbin thread is loaded properly.
If the problem continues, take it for service as the needle/hook timing can be off.
Apr 16, 2016 | Euro-Pro Sewing Machines
Bobbin will not pick up needle
when you insert the bobbin into the bobbin case and insert into machine, make sure there is a long tail coming out of the bobbin.
Thread machine correctly and when trying to "pick-up" the bobbin thread, make sure you are spinning the flywheel the right direction.
Jul 20, 2014 | Euro-Pro Dressmaker 998B
Euro pro 9130 Bobbin holder jumps out of place when sewing, then the machine locks up, tweets and stops sewing. I have ordered a new bobbin holder and that did not help.
check the upper thread tension
make sure all the thread guides all used- & that the thread is not hanging up some where on the machine
check the top thread tension dial to see if there is any thread caught in it
change the top & bobbin thread- make sure the thread is not knoty or old
Mar 12, 2012 | Euro-Pro 9130 Sewing Machine
How to thread euro pro 380a sewing machine lost mannel
My needle will not pick up my bobbin? I have tryed everthing! my bobbin was placed in the holder right. my needle is in the EP correctly! not sure if my Thread is correct in my machine. but I have read the manual and still cant get the needle to pic up. Can some one help me out on this! Euro-PRo 380A
Dec 16, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
Needle will not pick up bobbin threat
Try flipping the bobbin spool so the thread comes off in the other direction.
Forcing means that the needle has been jammed against the sewing plate ant the needle is now out of timing with the bobbin pickup.
May 31, 2009 | Euro-Pro 473
Zigzag stitch pulling tight, looks wrong
Try adusting the bobbin thread instead of the top. Always make sure to insert the bobbin so the thread is pulling in a clock wise direction. Both threads top and bobbin should have about the same resitance when pulled.
May 08, 2009 | Euro-Pro Shark 60 - 384
Thread jams & wheel axel cannot turn
there are a couple of things that come to mind.
Bobbin:   wound with uneven tension.  Try taking the bobbin, rewind that thread onto another bobbin and wind slowly.  make sure the thread feeds onto the new bobbin evenly.
upper thread:  catching on something or not flowing off the spool easily.
you're doing well, sounds like you consulted the manual and used your noggin, hang in there and let me know if this doesn't help.  we can troubleshoot some more!
Jan 12, 2009 | Sewing Machines
Feb 02, 2008 | Euro-Pro 473
Sewing Machines Logo
51 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
