Question about Luxor 19822 COB
Code fuego tv digit direct - Luxor 19822 COB
Can you give me the codes for the lg tv so I can program my remote to my new tv or a diffent way with out the codes please
hi Tammy.
this is all i could find.
4 & 5 Digit Universal Remote Control Codes For LG TVs
  • DirecTV (directv - direct tv) Remote Codes For LG TV: LG 5 Digit TV codes: 11423, 10178, 11178. ..
    PRESS IN THIS ORDER:
    "Menu" - "Settings" - "Remote" - "Program Remote" - "TV"
    Slide mode switch at top to "TV" - enter LG - press and hold "select" & "mute" buttons
    Wait for light to blink 4 times
    Enter 10178.
    Follow instructions.
    If volume does not work then repeat and enter code 11178.
    RCA universal remote codes for LG tv:
    LG TV codes: 1002, 1004, 1005, 1014, 1025, 1078, 1081, 1095, 1096, 1097,
    1098, 1099, 1100, 1101, 1111, 1128, 1130, 1132, 1134, 1144, 1149, 1171, 1205.
Dec 15, 2017 | LG Televison & Video
ANLOCK3 NOMBER KEY FOR FUEGO TV MODEL FE 29SL2T
fuego tv model fe14sl5.i cant open tuning menu step 5.,just open step 4 and over to end import code in service mode is 6483..need some help how to reset menu...my mail is gulevski@yahoo.com
Dec 04, 2011 | Home Security
Where is the fuel pump located in a fuego 1982 model? Is it electric?
Usually the fuel pump is located in the gas tank on most models....Hope this helps.
Feb 10, 2011 | 2006 Renault Fuego
Tv fuego
I dont know how to turn that asking but the key it is asking for is 512!
Jan 09, 2010 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Sentry really big universal remote
Ya it does work with the codes given.. Just make sure you are close to the tv or product you are wanting to program -- other equipment can interfer ... hold search code button down until it stays on then press tv/sat or what ever u want to program then put in the code then power button, item should shut off-- if it doesn't work then try the next code for the brand of tv/sat/vcr u have.. here is the web site with the manual on it..3 different models of this remote just select the one u have from the list on the left.
http://www.sentryindustries.com/category/remotes/remotes_rmc10.asp
Dec 25, 2008 | Televison & Video
Toshiba CT-90275 3 digit code for Direct Tv R-16
Not really too sure about Direct TV. But give me some time, I have asked some other Experts here for their help. Hopefully one or two of them may have an answer..
Please do not rate this solution yet..
May 21, 2008 | Televison & Video
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Feb 18, 2008 | Televison & Video
Direct TV remote control won't work with my new TV
These are 4-digit codes : 0054, 0030, 1454, 0020. Here are 3-digit codes : 006, 007, 010, 011, 013, 016, 027, 033, 035, 043, 066, 087, 089. Try these.
Dec 06, 2007 | Philips Magnavox 27MS343S 27" TV
Luxor 19822 COB Logo
27 people viewed this question
Top Luxor Televison & Video Experts
Sp Gupta
sureshd2008
rugby prop
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
