Question about KWorld PlusTV 330 (872880888463) Video Capture
Plus tv driver - KWorld PlusTV 330 (872880888463) Video Capture
Driver Hauppauge Wintv Nova-s-plus 92001
Go to the link given below and select your product from dropdown menu to download your driver.
Your product name is : Win-TV-NOVA- S- PLUS (92XX).
Here is the link you need to go:
www.hauppauge.co.uk/site/support/support_support.html
Nov 24, 2012 | Hauppauge Wintv Nova-s-plus 92001 Wintv...
Hi i need adriver fot tv card saa7130 for win7 64bit
Vista Drivers complete work in Windows 7
Name: Philips SAA713X, Hybrid Capture Device
Device ID: PCI\VEN_1131&DEV_7133&SUBSYS_00001131&REV_D1\4&2C30955E&0&10F0
WE NEED THIS!!!
Install Intructions:
First go into Add Remove Programs in Control Panel and remove any reference to
Tv Terminator 7131 like Quick TV,PVR-Plus and drivers and Utilities.
Go to device manager and right click on any driver for the 7131 and
choose uninstall. When you click uninstall, also check DELETE DRIVER so it
can completely remove drivers. If you only see Unknown Multimedia device or
similar, uninstall that and delete driver also.
How to install:
1. When you first get the Found New Hardware Wizard, click Cancel.
2. Then extract the files first, before using them. Run CheckOS in "Run as Administrator" to
install driver. Make sure you extract the files first before running or else
they won't work. Even though you can see all the files after you download,
you need to extract the files first.
3. Install PVR-PLUS and before running. DO NOT INTALL DRIVERS FROM CD. ONLY PVR-PLUS.
4. Right click on the PVR-Plus Aplication icon in: "C\Program Files\KWorld Multimedia"
and all folders inside, see all applications and go to Properties. Go to Compatibility mode TAB and
then put a check mark next to RUN This Program in Compatibility Mode.
Then choose Windows XP SP2 as the program to run in compatibility mode.
Do this in all Aplications to full funtion of your TV Card.
PLEASE.......IN THE WINDOWS VISTA UPDATE UNCHECK THE (( Philips SAA713X )) DRIVER UPDATE AND HIDE.
THIS DRIVER CAUSE COMPLETE NON FUNTION
DO NOT UPDATE YOUR TV CARD DRIVERS.
Download for you FREE in
http://www.megaupload.com/?d=E8S2JFQT
Update instruction by 64BIT
Proved, I have the TV card and some intrucction in the Kworld site, is not good.
Now is good intructions.
Result: >>> (( http://i41.tinypic.com/2uxzlh0.jpg )) <<<
New Pic of probe, the TV card Still runing and work good with SP1 of Windows 7 = http://i52.tinypic.com/2vadyea.jpg
Jun 04, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Please i lost my installation card for a Much tv plus PCI video capture card (SAA 7130). Even it requests for drivers of 713x. can you please asssist me down load a free installation Much plus CD. thanx
Click here to download drivers for Philips SAA7130 TV Tuner/FM Radio/Video
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Apr 14, 2011 | Philips TV Tuner Video Capture PCI Card -...
Archos TV Plus and Converter Box
The installation may be corrupt .Go to www.intel.com and again download & install the high definition audio driver from there
May 20, 2009 | Archos TV Plus, 80GB 80 GB Hard Drive
Driver and multimedia center
Hi!
try downloading your driver on these website www.driver.com
have a nice day
Apr 17, 2009 | KWorld PVR-TV 305U (KW-PVR-TV305U) Video...
Ssd 670 plus driver needed
I need Tech-com "SSD-TV-670"Tunner Software with driver
Feb 19, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Driver for TVAnyvhere Plus
you can download the drivers from some these sites ...
www.opendrivers.com/categorycompany/12/1569/display-and-video-msi-free-driver-download.html
www.opendrivers.com/freedownload/229987/msi-tv@nywhere-plus-driver-v2.4.0.4-windows-2000-xp-download.html
infopirate.org/driver-and-software-for-msi-tv-anywhere-plus-tv-tuner-capture-card
drivers.soft5000.com/driver6693.html
www.driversdown.com/drivers/13465.shtml
www.driversdown.com/drivers/13470.shtml
downloads.zdnet.com/abstract.aspx?docid=188492
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 09, 2008 | MSI TVAnywhere Plus (TVANYWHEREPLUS) Video...
Drivers
Hi
I've fixed this trouble!
The driver fron Avermedia is OK , but software is'n working under XP.
I've fixed this, by means of Intervideo Windv r6. gold   Using windvr6 gold , my Avermedia m135-c card (Hybrid) is perfectly working (analogic and digital)
As usually, Windvr fixes anything!
Regards
HD
Feb 18, 2008 | Avermedia AVerTV GO 007 Plus/FM Plus...
KWorld PlusTV 330 (872880888463) Video Capture Logo
24 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Ruben Balisbis
Ruben Balisbis
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
