SOURCE: I have a shakespeare sigma fishing reel that
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
SOURCE: shakespeare 2660 coarse fishing reel,cant remove spool cover
According to the intructions and I quote "Take off the cowling that covers the spool, twist off the pick up mechanism clockwise and a half turn anti clockwise will remove the spool"
SOURCE: Shakespeare fishing reel schematics
try online at www.reelschematics.com they should be able to give you help.regards barry.
SOURCE: I have a shakespear alpha fishing reel which
The switch is the on/off anti reverse switch. It is the switch (probably the only one) on the reel at the base. When the reel is in the upright position, look at the bottom/rear area. That little level controls the reverse. Good fishing...
Testimonial: "Hi Thanks "
