Question about Zebra LI4278 Barcode Scanner
Barcode with prefix (Data Identifier)
I want to scan a Barcode which with prefix (Data identifier), how to filter this prefix when scanning.
thesuperdude
  • 97 Answers
SOURCE: Do I need to purchase the Device Configuration Package?
Depending on what application your client will use, you will need to configure the scanner in which ever way suits your customer.
If you use a telnet client kind like wavelink, you can configure it from there. If you planning on using some other application that has not scaner api's, you will need to use datawedge which is available as a free download from symbol support.
The DCP is normally available free of charge, however motorola has changed the downloads policy for dcp and depending on the version, you may need to provide them with information of the terminal and request the download.
I hope this helps.
Posted on Mar 26, 2009
  • 9 Answers
SOURCE: Unwanted underscores added to 2D barcode scan
are they the same barcode type?
what is the font set at? using Arial or other fonts can make the software send a more complicated image. use the Zebra Triuverate font. this keeps it simple. also, do a print out of the settings on each printer and compare them line by line. change the settings to match the printer that is printing correctly.
Posted on Aug 31, 2009
Testimonial: "Thanks. Printing out the settings helped me realize it was not a printer issue. It was a software issue. Installing older version of software fixed it"
  • 32 Answers
SOURCE: Zebra S4M Lable Printer Not Scanning
You might want to check the barcode ratio, bar width, printer speed and printer darkness. I am assuming that you are creating the barcode in some sort of label design package, correct? You either need wider bars, or make sure you have enough quiet zone on both sides of the barcode, so shrinking it might be the solution as well.
Posted on Oct 27, 2009
kganoe
  • 42 Answers
SOURCE: motorola MC5590 is not able to scan barcode
download the datawedge file for the mc55. Its probably not loaded and configured. Once you have this file on the device and you need additional information please let me know
Here is the version 3.1.7
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12465&sliceId=&dialogID=162320658&stateId=1%200%20162316370
kganoe@datexcorp.com
Posted on Mar 25, 2010
ozztech
  • 285 Answers
SOURCE: we use 2 column lables
possible, need printhead replacement. Try to.
Turn printer off,
press pouse button,
turn printer on, still pressing pouse button for 10 seconds, and then relese the button. the printer will print the pouse test with barcode, check if coming with wihte lines across, if yes, change printhead.
Posted on Mar 26, 2011
How to program a bar code scanner to have 3 "TAB" in prefix
In the appropriate manual (see link)
https://portal.motorolasolutions.com/Support/US-EN/Mobile+Networks+RFID+and+BarCode+Scanners/Bar+Code+Scanning/General+Purpose+Scanners/LS2208_US-EN
Go to the proper symbology page scan the prefix start then find the tab character and scan it three times to add the prefix then scan the complete barcode for the prefix
May 16, 2016 | Zebra LS2208-SR20007R-UR
How do I get prefix and data both in cs3070
Chrish
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
Dec 31, 2014 | Symbol Cs3070 Usb Batch/Bt Scanner Kit
Gryphon gm4100 ean 128 ]c1 identifier
1. Download Product Reference Guide (PRG), Gryphon I GD4100/GBT4100/GM4100 and Gryphon L GD4300 (English) Manuals .
2. Go to Page 80, Section titled GS1-128 AIM ID.
a. Scan the Enter/Exit Programming Mode code.
b. Scan the GS1-128 AIM ID=Disable code.
c. Scan the Enter/Exit Programming Mode code.
Feb 22, 2012 | Datalogic Gryphon I GM4100 Barcode Scanner...
What would I put under the suffix and prefix when bar coding? My scanner is Symbole LS 2208
Hello Norma, you can use the suffix or prefix to send characters, which are not included in the barcodes tgehter with the scanned barcode data.
If you dont need any character before or after the data, you can leave it blank.
It is usually used to add an Enter or Tab to switch to the next line, while scanning to some application like excel.
Nov 02, 2010 | Symbol LS2208 Handheld
Need to add prefix ~ and suffix / for ls2208. I have no problems programming other brands, but symbol has me stumped. The code for ~ is 1126 right? So I tried scanning the 'scan prefix' barcode, then scan...
Have a read through this document.
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
look at 13-4
have you tried scanneing the enter barcode after 6 ?
Oct 08, 2010 | Symbol LS2208
I hope this helps.
Mar 13, 2009 | Zebra Symbol Technologies MC909X-G Series...
Any way to lower the beep sound ...
this are all barcode to solve u r problem.......
please tell me how to set prefix /suffix values ?
i have already set scan prefix & scan sufix and then scan option ...
but did not get the< prfix ><data>< suffix> only data will retrive...
prfix value is `key, suffix value is Tab !
please help me
Feb 04, 2009 | Symbol LS2208 Handheld
Removing leading zeros from barcode???
Prefix/Suffix Dialogs
The Prefix/Suffix Dialogs allows configuration of DataWedge options.
Two data entry fields are used to display and allow entry or editing of prefix and
suffix strings. The prefix string, if present, is transmitted before the data for any
barcode scanned. The suffix string, if present, is transmitted after the data for any
barcode scanned.
The following checkboxes are used to display and allow modification of various
DataWedge options:
Allow escapes in prefix/suffix (default = disabled)
Enabling this option allows escape sequences to be embedded in prefix and
suffix strings. Escape sequences allow non-textual data to be transmitted as
part of the prefix or suffix string. All escape sequences begin with the backslash “\”
character. The supported escape sequences are:
\b Backspace
\f Form feed
\n New line (line feed)
\r Carriage return
Apr 14, 2008 | Symbol MC70
Zebra LI4278 Barcode Scanner Logo
79 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
