Question about Peerless WV-DV-04, Oil Fired, Hot Water Boiler, Taco 007 Pump, Riello BF5 Burner Up to 2,000 Ft Altitude - 182,000 BTU
Wiring Diagrams burned wires need replaced peerless oil boiler to blue angel burner
    Scholar:
  • 161 Answers
Check out this site
www.peerlessboilers.com/Products/ResidentialBoilers/
SeriesWBVWV/tabid/118/Default.aspx#dnn_relateddocuments
Posted on Oct 18, 2013
Tip
Peerless boiler
This boiler us one of the best on the market!
on Sep 23, 2013 | Peerless G63-03W Residential Hot Water Gas...
Tip
Cruise Control for Your Oil Burner to Save Money
The Beckett HeatManger is a microprocessor controlled device that will manage the on/off cycles of your boiler. Every time your boiler has to shut down and then restart your have just lost a bit of efficiency. By reducing the start/stop cycles of your boiler you not only reduce fuel consumption, but you also reduce wear on the parts of the boiler and emissions coming from your boiler. Your burner burns very inefficiently on startup and shut down. When I have my combustion analyzer on a burner it goes crazy with bad gasses right after shutdown.
If you have a fuel oil or gas fired boiler and you are wondering how you can save money on your heating bill without replacing your boiler then I have good news for you! By adding a simple device to the burner of your boiler you can be saving at least 10% in minutes
With this control if your thermostat requests heat and the HeatManager has sensed that there is heat available in the boiler, it will not start the burner until the heat is used up. When the burner is running, the HeatManger will optimize the runtime to match the boiler output to the load.
The unit is very easy to install. It is mounted to the junction box under the relay and wired into the normal burner relay wiring. There are a couple of sensors that need to be attached. One senses the supply water temperature for heating, coming out of the boiler and the other senses domestic hot water boiler supply temperature.
Even if you would decide to get a professional to install this unit you will be on the road to saving big dollars while only spending few hundred bucks. Then when the price of fuel oil and natural gas begins to rise again, which it will this winter, you will be getting even more savings from your small investment.
Saving money is always a good thing, but when you can combine saving money with greater comfort than I would call that a great thing!
on Dec 17, 2009 | Heating & Cooling
Wiring diagrams forthermostat from boiler
Does the Thermostat say it can control and A/C also? The blue wire is for Air Conditioner and does not connect to the boiler.
Aug 17, 2014 | Heating & Cooling
Riello 40 burner giving off black smoke,new pump and nozel installed same problem?
Black smoke indicates a lean burn - meaning that the fuel to air ratio is to great for optimal combustion. This will cause a soot condition in the heat exchanger very quickly and drop efficiency. Too much air will make the burn to lean. The oil burner technician will do a smoke test and adjust the air intake damper on the burner motor as part of an annual tune up that includes setting the amount of carbon dioxide, excess air, stack temperature, draft and more. Doing so will provide the most efficient transfer of energy in the fuel to heat your building and prevent premature failure of the burner and furnace. To do this properly, you need the right test equipment - it can not done by "eyeballing" it.
Feb 25, 2014 | Heating & Cooling
Peerless Boiler - Turned off boiler to replace Circulator for the hot water. Turned furnace back on. Did not ignite. Tried to hit the reset button for 30 seconds and nothing happened. Furnace will
Did you bleed the air out of the pump. The boiler has a flow switch that has to make before it will let the boiler lite. Make sure you have all of the air out of the system and are pumping or flowing water and not air...Also check to see if you didn't happen to of tripped the limit it has a manual reset. Red Button on the front of limit.
Nov 13, 2013 | Heating & Cooling
Need wire diagram from the hot wires feeding a blue angel oil burner and blower motor
Dean,
What kind of primary control? Beckett?Honeywell? Carlin? Control model #?
Oct 18, 2013 | Peerless WV-DV-04, Oil Fired, Hot Water...
Utica Boiler model # MGB100HD with a Honeywell Aquastat Relay model # Type L8148E will not operate the circular pump. THe damper works and I can hot wire the circulator pump but it won't turn on...
how did you hot wire it. did you jump the wires on the relay board or use another power source? Does the boiler burner start? Have 120 volts incoming to the relay board? You hear relay click when turning power on/off? If so bad relay, or loose wiring terminals on the board. This control has built in transformer that can burn out, that will stop the pump relay contacts from working.
Nov 07, 2011 | Honeywell Programmable Thermostat Heater
Have a 1979 firebird need to know what color the oil sending unit wire is, also the temp sending unit wire
you can find wiring diagrams on the autozone.com site. become a member and log in.
Nov 02, 2010 | 1979 Pontiac Firebird
Wiring diagrams schematic (boilers)
call me alan 0776 7494009 have books on c, s,y plans
Mar 04, 2009 | Cooper Wiring Devices 1301-7B GROUNDING...
Peerless WV-DV-04, Oil Fired, Hot Water Boiler, Taco 007 Pump, Riello BF5 Burner Up to 2,000 Ft Altitude - 182,000 BTU Logo
155 people viewed this question
Top Peerless Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Peerless Heating and Cooling Expert? Answer questions, earn points and help others
