Question about Kenmore Dehumidifiers
MY KENMORE ELITE 25190701010 HAS ALWAYS WORKED,
MY KENMORE ELITE 25190701010 HAS ALWAYS WORKED, BUT SUDDENLY ALL THE WATER IS GOING IN THE FLOOR
Why is my Kenmore Energy Star 50 pint model 251-50501012 dehumidifier leaking water after I disconnected the drain hose
If you reconnect the drain hose, make sure that it lays flat from the dehumidifier and into the sump pump hole. I did that and it solved my problem of water leaking onto the floor.
Jun 15, 2014 | Kenmore 50 Pint Dehumidifier Electronic...
My Kenmore Elite Dehumidifier model 42-99701 runs but does not cool enough to collect water. Not a drop. found this page where I can order parts but I don't know what part I need to replace. Please help....
Dehumidifers are cheaply made and most likely it has formed a refrigerant leak. It would cost more to repair than to replace with a new one. They are basically a disposable appliance.
Oct 12, 2013 | Kenmore 54501 Dehumidifier
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Kenmore Elite dehumidiefier 251.90701 Does not pump. Had for about a month. Worked initially. I can not remove the plastic drainage tube to reset it. If this is a help Bob
Bob, it may not be necessary to remove the drain tube, if the unit is not collecting humidity out of the air. As, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level.
in basement applications Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
To further assist you, in case you have misplaced your Owners' Manual. I have provided a link to it that you can download & print for future reference. http://www.hammerwall.com/Download_Manual/124595/
I hope this will help you troubleshoot and solve the problem.
Jul 12, 2011 | Kenmore Dehumidifiers
Re: Kenmore 54501 dehumidifier. Both fan and compressor sound as though they are turning on, but no water is evaporated into the water bucket. The unit had always operated properly during past seasons,...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 24, 2011 | Kenmore 54501 Dehumidifier
Kenmore Elite 70 pint unit. Compressor appears to be frozen. Fan runs and compressor attempts to engage but immediately shuts down. Any suggestions. Unit is only about 2 years old.
Hi, I think you got it figured out...
There can be many reasons why a dehumidifier willnot work or collect water.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 15, 2010 | Kenmore 54501 Dehumidifier
Elite model worked great,,,now displayed temp and rh seem way off, and hardly ever turns ons
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 25, 2010 | Kenmore Dehumidifiers
Humidifier suddenly stopped collecting water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
Aug 17, 2010 | Kenmore Dehumidifiers
Water leaks out of the bottom of the humidifier and the bucket does not fill up. The water just leaks out.
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Apr 22, 2010 | Kenmore 54701 Dehumidifier
Kenmore Dehumidifier Model 53701
Assuming the unit is level look for a blockage in the drip pan outlet causing it to overflow.
Good luck,
Gilsh
Nov 27, 2009 | Kenmore 53701 Dehumidifier
Dehumidifiers Logo
37 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
