Question about NordicTrack Exercise & Fitness
I have a Ntl 1094 Track C 1900 and the problem i have is ; the drive motor for the belt trips a breaker in the house breaker box. The belt will start and run for approx 5 seconds and the the breaker trips. where do i start checking ???
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
First check and see what the circuit is rated at. it you have too many thing on that circuit(light,tv,etc) this will trip your breaker because of the amp draw of the treadmill. nordictrack recommends a dedicated circuit of 20amp. you may nned to have a circuit put in with 12/2 wire
Posted on Nov 28, 2014
5 Suggested Answers
  • 40 Answers
SOURCE: Runs for a few seconds and trips a breaker in the house
If it's the breaker in a gfci outlet, move it to one that isn't GFCI.
The motor isn't going bad, but if it's not a gfci outlet, it may be the motor control board and of course the belt need lubricating.
Posted on Nov 01, 2009
  • 42 Answers
SOURCE: The circuit breaker trips when i get over about
hi, firstly if you are using a extention wire unroll the whole thing, and putting a higher amp volt in the plug. this should help
Posted on Nov 21, 2010
AJIN G
  • 6694 Answers
SOURCE: Hi. I have Proform 450CX.
hi,
You have to check the Driver circuit board for the motor. From your naration the motor is ok . Why the circut breaker trips because, if the IGBT( insulated gate bipolar transistor) is short then, when you press the start button the motor will try to drain a high current from the power line.IGBT controll the voltage to the motor.When it get shorted the applied voltage will gos to the motor without regulation. Also you have to check the rectifier diode. The IGBT will look like one in the picture. Check the ohms between the seond and third pins of the IGBT. It should be above 1 kohm. Remember one thing remove power before oppening working in the treadmill. Because it have live area all over the driver board
ok
Posted on Jul 30, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill nordictrack c 1900 motor doesn't run, belt doesn't turn
1) Lube the deck belt, in according with the instruction manual.
2) Lube the rollers bearing, with the i. manual
3) Test the input voltage motor, if there are the motor need repair
4) Test the output voltage board, for input voltage motor, if there are Not the board is faulty. God bless you
Posted on Jun 03, 2012
My 933i is tripping my house circuit breaker at higher speeds. I think there is more resistance in the belt (It's never been serviced).
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt monthly. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine. -
Precor Repair Parts for 9 21s 9 21si Treadmills Consumer SPORTSMITH net
The following link will take you to our tech support page that contains some tips and videos on how to maintain your treadmill:
SPORTSMITH LLC
Sep 21, 2013 | Precor 933 Premium Series Treadmill
My belt will start but will stop right away with an error tone from the control panel. It also blew a fuse in that part of my house. Any ideas?
1) LUBE the deck belt, this happen because the lack of maintenance LUBE, and lube the rollers bearings too.See the video attached
2)Test the input voltage motor, if there ARE the motor need repair see my personal TIPS for motor help
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
However you put some desklamp in the circuit if the breaker in tripped the problem is the outlet wall. Test the outlet+wires and ground for incorrect wires polarities see the diagram attached and fix it.
If the c.breaker are NOT tripped the problem is the treadmill. do the LUBE first.
Jan 21, 2013 | Nordic Track NordicTrack A2350 Pro...
Trips breaker when motor stops
what size of motor is it,it may be overloading your breaker box,this can cause a serious problem
Dec 29, 2011 | Air Tools & Compressors
Nordic track treadmill trips breaker
1) I am assuming that the breaker is the treadmill and Not from your house.
2)you must test the Main Motor. measure the voltage without load
3)now you must test the main motor controller board.
4) transformer.test .see the block diagram and see how the main motor board has aprox 90% of functions of any treadmill.
12_14_2011_4_11_07_pm.gifGood luck. Sincerely. G-d bless you
ERNESTO CUADRAMANAGUA, NICARAGUA C.A
Dec 14, 2011 | NordicTrack Treadmill
Air compressor is about 10 years old. Used for light duty work only. It trips the breaker in the box after about 1-2 seconds running. Has been plugged into same oulet never moved. Tried in different...
Hi hbkopen31...
Your problem sounds like it is the motor giving a problem.
Unhook the belt from the compressor and run the motor by itself...check the compressor to make sure it is not dragging the motor too much making the amps go up and tripping the breaker..
If the motor runs with the belt off of the compressor, then let it run for at least an hour, then put the belt back on and try it again...if it trips again, then replace/rebuild the motor as it is faulty.
Also check the motor capacitor sometimes they fail..
If the motor still trips the breaker after removing the compressor belt..replace/repair the motor as it is faulty.
Please take time to rate me
Sep 05, 2011 | Garden
Thermal overload on motor keeps tripping around speed of 3.2 when being used. Will run at 11 for 5 minutes without anyone on belt. House breake does not trip in either case
I would check out the condition of your belt and deck.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
Jun 29, 2011 | Precor 9.31 Treadmill
Pump plugged in to grounded receptacle trips the
If by "trips the breaker" you mean the GFI then you are leaking current to ground, GFI's trip when there is an imbalance between the current going to the motor on the HOT side and returning from the motor on the NEUTRAL side, if it is tripping the GFI it is likely the sign of a failing motor.
May 27, 2010 | Little Giant WGP-65-PW 1/8 HP, 1900 GPH...
No heat in dryer
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | KitchenAid Dryers
The dryer isn't getting hot. I know there's a
Hi
• Empty dryer.
Thanks
Rylee
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer started up as normal, but, midway through cycle, it stopped running. Timer was still going, but dryer is not spinning.
Can you hear the motor turning? If yes, it probably has a broken belt that drives the drum. If no, check the house electrical power panel to reset the dryer breaker(maybe, only one of the breaker pair tripped). If breaker trips again, you have an electrical short in the dryer cabinet somewhere, usually in the heating element in back of the drum. Good luck!
Jul 09, 2009 | Dryers
Exercise & Fitness Logo
188 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
