Question about Frigidaire FFLE2022MW Electric Washer/Dryer Laundry Center
Brand New Frigidaire FFLE2022MWO. Washer will restart a few minutes after wash cycle ends.
SOURCE: Affinity E21 error
E21 means "Not pumping out fast enough". Could be debris caught in the pump inlet sump or pump body.
a75737b.jpg Disconnect the inlet sump from the pump. Disconnect the outlet hose from the pump. Remove the (2) screws, one on each side, holding the pump housing to the washer base. Unplug the wires from the pump motor and lift the pump assembly out.
Posted on Feb 08, 2008
  • 101 Answers
SOURCE: FRONT LOAD WASHER
ther is something blocking the drain pump, check the water coming out from the drain if its floating out good if not there may be a sock or a bra wire inside the pump.
Posted on May 12, 2008
SOURCE: error messages EFO and E10
It is simple. The wrong soap or too much soap will caused EFO to flash. I overfilled the machine with soap by accident. It started flashing with EFO and I went nuts. What could be wrong with it now?! Too much soap or not the right kind of soap will cause this problem.
Plus, I found a sheet of paper that gives the codes.
This is better than when the strainer plug gets filled up and you have to take the machine apart to clean the little strainer.
Posted on Oct 25, 2008
  • 3 Answers
SOURCE: won't wash
press the pause and stop button at the same time it will give u a code
Posted on Mar 21, 2009
SOURCE: frigidaire washer model #fwt425rhso
This is the second time I have had to replace the drum/support shaft on this washer. Not only is it expensive, but very difficult to replace. Probably the very worst washer on the market for this reason. And I only do 3-4 light loads of laundry per week. A definate design flaw on the part of the manufacturer.
Posted on Oct 20, 2009
Why does my new Frigidaire washer do 6 wash-cycles (washes for approximately 4 minutes out of a 50 minute planned wash) then spins and drains?
Who installed the machine? If it is a front loader did you remove the shipping bolts? If it is installed correctly I'd say it has a bad control board.
Unplug the machine, let it set for one hour and then try it again.
Oct 22, 2014 | Frigidaire Washing Machines
Code saids pau
If the PAU error does not clear after properly restarting the washing machine cycle, push "Cancel," then disconnect the power cord. Wait a few minutes and restore power to see if the error code goes away. If not, the control board may need to be replaced.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Reset frigidaire affinity washer
Yes there is buy a new drain pump so all the water will get out
Jan 19, 2014 | Washing Machines
Brand new Frigidaire FFLG2022MWO Washer/Dryer Laundry Center. After a wash cycle is finished, the washer will start again after a few minutes. A truly never ending cycle. Please help.
Good Afternoon Mauricio, thank you for your question! Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the appliance. Select a normal cycle and verify if the washer continues to run after ending cycle. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board, timer or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Aug 19, 2013 | Frigidaire FFLE2022MW Electric...
Won't wash
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Front Load Washer
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Mar 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Lock won't release on washer
Sometimes if you unplug it from the wall outlet for 5 minutes, then plug it back in and let it go through a fresh startup cycle then it refreshes and resets itself and may unlock switch.
Jan 18, 2018 | Frigidaire FLGB8200DS Top Load Stacked...
Frigidaire FFLE2022MW Electric Washer/Dryer Laundry Center Logo
91 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
