Question about Maytag MER5752BAW / MER5752BAQ / MER5752BAB Electric Kitchen Range
Maytag Stove MER5752BAW Sometimes the "on" indicator lights stays on when the burners are turned off. Sometimes one of the burners does not turn off even when the knob is in the off position.
catriver
  • 878 Answers
SOURCE: Sealed Burner
Ralph, you need to look at the electrodes at the burners. They might be cracked or dirty. It's very hard to tell sometimes when they are cracked. The burner cap itself has to have a good ground and the wires going to the electrode should be on tight. You can eliminate the spark module by switching the right and left side burner wires at the module. Once you do that, if the right side works ok, but now the left doesn't, you can be pretty sure it's the module...Catriver..post back.
Posted on Mar 03, 2007
SOURCE: Clicking sound on my gas stove
there switches behind each knob, 1 of them is broken,or wet, when you remove the knobs then remove the knob panel you can test them and find the bad one,they are no more then $15.00 each. to test you can plug the stove and disconect the switches one at a time until you find the bad one replace and you are back in bussines.
Posted on Dec 12, 2008
  • 41 Answers
SOURCE: Light indicator when burner is turned on will not shut off.
if there is one light for all the switches, you will need to unplug the unit, take off the top part of the back panel to get access to your switches. the indicator light is run to all 4 switches. you will need to unplug the wire that goes to the indicator light from each switch ( only one at a time ) and plug the unit back in each time. do this for every switch until the light goes out. whichever switch has the indicator light wire removed from it when the light goes out is the switch that needs to be replaced. if your unit has an indicator light for each switch, then just replace the switch that is above the indicator light. Joe
SOURCE: burner on glass stove top has turned black
The nice grey-flecked surface coating is very thin; the solid black is underneath. You've "cleaned" the coating off -- that's why further scrubbing just makes it worse. We did the same thing :-(
Posted on Apr 25, 2009
  • 10865 Answers
SOURCE: Maytag Gemini gas stove top ... while starting one
You have a gas leak which resulted in the unwanted fire. This has the potential to be serious or deadly. This is one time when you need to get a pro in there to stop this leak and get your stove safe again.
Posted on Jun 16, 2009
On my electric stove, one of the burner caught on fire, and now the indicator light stays on even after the stove is turned off
If the light remains on, that would indicate the circuit was damaged. The light goes on when the circuit is complete. This usually happens when the burner gets hot. If it caught fire, then the stove is registering it as hot all the time.
Elisa Jed ' http://www.atlasappliances.com/en/pg-kitchen-appliances
Jul 07, 2014 | General Electric Stove/Oven/Range Chrome...
Electric range for maytag gemini stove doesn't coem on. Clock and controls appear to function. This is after I turned the house's breaker off then on again. The "On indicator" light does not come on when I...
Turn it off at the circuit breaker and leave it off for a few minutes,sometimes the microprocessor will reset itself. When you turn it back on make sure the safety switch is working ok they usually have a test button on them.
May 01, 2014 | Maytag MER6772 Gemini Electric Kitchen...
The surface light on my mothers stove stays on and all burners are off and cold any ideas why
Here is a tip that I wrote about why the hot surface indicator light will not go out...
Oven Hot Surface Indicator Light stays on
heatman101
Jan 18, 2011 | Maytag Cooktops
The burner indicator light on my GE profile glass cook top stays on when the stove is turned off. Any thoughts?
mine does the same thing, in my case it is just indicating the burner is still hot after being turned off.. it goes off after awhile, which is normal.
Oct 09, 2010 | Kitchen Ranges
Frigidaire Oven surface light stays ''on'' even when cooktop off
I unplugged the stove, un plugged all the burners cleaned them, put them back on plugged the stove back in and the light went out, something to do with unplugging it I think. reset it or something.
May 10, 2010 | Frigidaire FEF326 Electric Kitchen Range
Oven takes forever to pre-heat and then doesn't keep the temp constant. turning on stove burner helps sometimes, and sometimes it works fine. do we need new thermostat or...? not sure if i have right...
Very common problem, I would replace the oven ignitor first as they get weak with time and cause intermittent burner lighting. Good Luck, Appliance Specialists
Dec 31, 2009 | Maytag MGR5750 Gas Kitchen Range
Indicator light stays on when eye(s) are turned off
The stove indicator light normal stay on until the burner cools off, and then the indicator light goes off, this is to prevent someone from touching the burner, alerting them that the stove is still hot.
Dec 11, 2009 | Kenmore Kitchen Ranges
Burner will not turn off
I would first check the infinite control switch (#WB24T10029) the part the knob slips onto. The next thing I'd check is the erc (#WB27T10231) control board. Hope that is helpful!
Mar 05, 2008 | GE JBP64 CleanDesign Electric Kitchen...
Maytag MER5752BAW / MER5752BAQ / MER5752BAB Electric Kitchen Range Logo
51 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
