Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
Bissell 9400-3 brushes wont turn - Bissell 9400 ProHeat Upright Wet/Dry Vacuum
reddevil6
  • 1673 Answers
SOURCE: Bissell 9400 ProHeat Upright Upholstery Hose
Set Ready Tools Dial to the Hose
Setting. This will allow spray and
suction from the hose.
Set Custom Clean Dial for Heavy Traffic, Normal
Clean, Light Clean
, or Rinse, as desired
Attach the cleaning tool to the end of the hose.
Plug in and turn on the Power Switch and Heater
(if desired).
Clean by pressing the trigger to spray solution
onto the area to be cleaned. Slowly move the tool
back and forth over the soiled surface. Release
the trigger to suction soiled water. Continue to
clean in the area, working in small sections, until
no more dirt can be removed. Rinse (optional)
and suction as needed.
Posted on May 26, 2008
SOURCE: brush will not turn
Possible Solution: I had the same problem with my Powerforce vacuum. Please take note that I AM NOT a vacuum cleaner repairman, nor have I played one on TV. Try taking your beater bar out, and if it looks similar to the one pictured (Model#203-1195), get a cresent wrench. Look at the end of the beater bar one will be squared on the sides to hold the shaft inside statonary. Take the wrench and adjust it to fit the nub on that end. Grab the bar in the center, and turn the end with the wrench. Mine popped and came loose, then it could be turned by hand. A little light oil allowed to run into the end cap, turn it up and spin it a few times to let the oil work down the inside and put it back on. Mine works fine for now. Good Luck!!
Posted on Mar 16, 2009
  • 672 Answers
SOURCE: Bissell 9400-E carpet cleaner
Take this link to bissell and click on Pro heat 2 x select user guide. http://www.bissell.com/Product_Search.aspx?Criteria=9400-E
Posted on Jun 30, 2009
heatman101
  • 43501 Answers
SOURCE: MY BISSELL PROHEAT WONT SUCTION
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ffuutr
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Bissell ProHeat, Brush won't turn, belt fine.
heatman101
dh
I replaced both belts and still the brushes won't turn
Hello, this is Ava with Think Crucial.
You may need to clean your roller brush first and try to see if this would resolve the issue. If not, then most likely your roller brush needs to be replaced.
You may order replacement parts for your Bissell directly to us. This is our Bissell replacement parts: http://www.thinkcrucial.com/collections/vacuums/collection-filter-fits-vacuum-bissell
As a special offer here is an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Think Crucial Customer Care
Oct 11, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
How do I turn on brushes?
Here is the Instruction or User Manual for the 8920, 9200, 9300, 9400, series machines....
Aug 15, 2012 | Bissell 8920 ProHeat 2XTM Upright Vacuum
Manual for a Bissel pro heat
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
Here is the Instruction or User Manual for the 9500 series machines
Aug 05, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
Brushes do not turn
You should see if the brush belt is broken. I broke mine you can find the part at walmart or on bissell.com
Sep 02, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Reset button
Do the brush rolls turn ok? The brush roll motor may be bad.
May 19, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
I bought a Bissell 9400 steam claner, but the brushes aren't spinning. what am I doing wrong?
If the belts are ok, then the brush roll motor isn't running and it may be bad.
Apr 28, 2008 | Vacuums
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
46 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
