Question about Skagen 355LGSC Wrist Watch
Skagen ladies watch
I replaced the battery but can not get the back to close properly.
  • 1 more comment
  • Anonymous Mar 06, 2008
    How do you replace the battery in a skagen watch?
  • Anonymous Jul 06, 2008
    take off crown
  • Anonymous Mar 20, 2014
    I want a user manual to tell me how to set the various dials on this watch.
Izzi, I assume you have a snap back back that won't snap back in place. I had the same problem with a Timex EXpedition. The solution should be similar. See my post" http://www.fixya.com/support/t190459-watch_battery_replacement and also the site I reference there. http://www.online-batteries.co.uk/whichbattery.shtml Good luck, Richard
Posted on Sep 28, 2007
SOURCE:
Is there a watch battery replacement for aFossil Architects 371 battery
There are plenty of charts for battery equivalent on the Internet.
so open and remove battery then identify or bring to battery store to purchase new one.
opening the back you may need spanner type tool.
it may be easier to just bring to battery store for replacement.
i purchased tools and batteries from Amazon for doing watches in family. Figured saves about $80.00.
proper tools will help don't forget a closing clamp for snap close styles.
Oct 01, 2016 | Watches
Replacing a battery on a C9 by Champion Womens watch
to change the battery in a champion watch:
(1) remove the back, (2) carefully peel loose the foam strip and set it aside (3) release the battery retaining bracket with a needle or awl and tweezers, (4) grasp the case with your thumb and forefinger so that your thumb is holding the works inside the case, (5) turn the watch over and the battery should fall out (6) put the new battery in the holder, (7) snap the retaining bracket back in place (8) replace the foam strip (9) replace the back 5b238361-61b1-4b0d-ab40-54fb346f5586.jpg
Dec 07, 2013 | Geneva Watch Group C9 by Champion Womens...
Battery replacement in wvq141 watch
Remove the back of the case. Remove the dead battery. Replace with a new battery. Close case back set time and your all set till it dies again.
Nov 10, 2013 | Casio Waveceptor Atomic Radio Controlled...
How to remove watch back
here is some videos that may help you
Mar 14, 2013 | Watches
Casio says open
The open code is saying that your case isn't closed properly. Without seeing it, it's hard to tell if you opened/closed the case correctly. If you believe it is closed properly, look in your user manual and see if there is a master reset button and try that. Did you change the battery yourself or did you have a jeweler do it?
Jun 23, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
Is it possible to change the battery on the Technomarine 10900 at home (with the proper tools) or do I need to get it to a repair centre?
It is possible. Open the watch case back, memorize all the writings on watch battery as well as how the battery is positioned (+ and -). Buy exactly the same battery, replace it and close the case back. To be sure case back is closed as tight as it was, draw fine line across the case and case back with non-permanent marker. This will help you align when closing the watch and you can clean it off later. Rate me, please.
Apr 26, 2010 | TechnoMarine RSQC11 Wrist Watch
How can I change the battery in my Casio Oceanus Oc-501? What battery does it take please and do I need to reseal the back?
I dont recommend anyone change their own battery unless they have the proper tools to open and close it! If the case back unscrews then you need a case wrench...if it pops off with a knife then you will need a case press to close it or else risk breaking the crystal! Most require equal pressure around the entire edge of the case back! Save yourself time and frustration and possible damage and take it to a reputable watch repair shop!
Jan 19, 2010 | Casio Oceanus Watch OC503
How do you change the battery on the T-Touch Expert watch?
I would not recommend changing this battery yourself unless you have the proper tools to close the case! If its a screw back then you will need a case wrench to close it otherwise you will scratch the case and case back! Plus it has a touch sensitive crystal! Screw that up and you will have to send it back to Tissot to have it repaired! That will NOT be covered by the warranty!
Jan 09, 2010 | Watches
Casio Pathfinder PAG-50 battery replacement
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
Mar 28, 2009 | Casio Watches
Cannot re-close Bulova watch after replacing battery
Not the answer I was hoping for, but apparently there is a "press" that jewelers use to reseal water resistent watches. There is a reference to it on this website: http://howtochangeawatchbattery.com/changing%20a%20watch%20battery%20page4.htm
Nov 12, 2008 | Bulova Watch
Skagen 355LGSC Wrist Watch Logo
437 people viewed this question
Top Skagen Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Skagen Watch Expert? Answer questions, earn points and help others
