Question about Homelite Leaf Vac Attack
Spark plug gap for a homelite vac attack 2 - Homelite Leaf Vac Attack
4 Suggested Answers
  • 5 Answers
SOURCE: Need a user manual for Homelite Vac attack 2
I have a Homelite UT08107
Leaf Vac, I couldn't get it started so I took it completely apart and cleaned it all up and now I can't figure out how to put it back together. I'm looking for a shop or a servive manual
Posted on Sep 04, 2009
Dolfoff
  • 148 Answers
SOURCE: I need the proper gap for a new spark plug for my
Proper gap is .030 inch.
Hope this helps,
Dolf-
Posted on Oct 16, 2009
Testimonial: "got the proper gap from the homelite manual online (.025) thanks"
  • 3 Answers
SOURCE: We have a homelite Vac
Clean the carburetor. might do it for you.
Posted on Nov 07, 2010
I would like to take my homelite vac attack apart and clean it and change oil and change spark plug and clean the gas line and other parts and put it back together. So I need a list of how you clean the...
go to www.ereplacmentparts.com for a diagram. just pay attention when taking apart. its not hard. even lable parts if you need to. an air compressor will be useful in cleaning. and brake cleaner does good on oily parts.drys quick and leaves no residue.
Jul 09, 2011 | Homelite Leaf Vac Attack
My Homelite vac attack 2 won't start. It's out of
My Homwlitw Attack ii won't start. Spark plug is dry even after priming more than 10 times. Where so I start? Thanks, Fred
May 05, 2010 | Homelite Leaf Vac Attack
I have the homelite Vac Attack 2, i'm having trouble starting it, i prime it the desired 7 times (actually more) but i just sit there and pull, and pull, and pull the cord....really getting frustrated!
#1 senerio
Fouled spark plug
ie, carbon and or fuel fouled
install new plug, and withouth choking or priming, pull 4-6 times while holding the throttle at wide open.
If not fouled, go to senerio #2
#2 senerio
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 09, 2009 | Homelite Leaf Vac Attack
Homelite Vac Attack II chord won't pull
Basics to check:
1) Spark plug - brown or dark brown - OK
- aluminum or silver - piston/cylinder scored
a) is it carbon or fuel fouled
b) is there spark
2) Compression - 125 to 150 psi
3) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
Nov 07, 2009 | Garden
Will not start
Homelite leaf blowers that use whats called a half crankshaft system are prone to many problems. Whats a half crank system you ask? If there is a small aluminum plate that attaches to the side of the engine by the gas tank you have one of these. Usually held on with 4 small bolts. I just got rid of a Homelite Vac Attack 2 that had spark and compression but the compression checked low about 75 should be 90 or better. What happened, a head bolt came loose and the engine ran lean causing the fragile rings on the piston to heat up and when that happens they loose their outward spring that seals against the cyclinder walls. A simple compression check using a gauge and not your finger will tell you that. Other causes could be less than normal spark, or maybe the exhaust port under the muffler has carbon build up or the muffler is plugged up also Check all bolts, and nuts to make sure they are tight.
Glenn
St. Paul, MN
Apr 15, 2009 | Homelite Consumer Products MightyLite...
Homelite Leaf Vac Attack Logo
81 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
