Question about Konica Minolta Office Equipment & Supplies
Minolta dialta di 550 to connected to network plaise ? tank you
sir fixalot
  • 146 Answers
SOURCE: error c12c0 in minolta di
C12CX (X is any value) deals with the hard drive
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Posted on Nov 11, 2008
firecontrol7
  • 6161 Answers
SOURCE: Minolta dialta di 181 error no c1440 machine not
Scanner exposure lamp out. Try opening thr front door to reset, if not new lamp
Posted on Jul 12, 2009
firecontrol7
  • 6161 Answers
SOURCE: MINOLTA DI 550 ME DONNE CODE C-OF24
Code is indicating a problem with the Automatic Image Density Control. A sensor that look at the drum and determines ability of the drum to hold toner and image. Open close front door should reset it. If it comes back clean the sensor, Drum may need to be replaced.
Posted on Jul 19, 2009
  • 6 Answers
SOURCE: caro esperto codice errore c0510 minolta dialta di
Amico C0510 - fusione fallita (temperatura di fusione del basso anormale) temperatura del termistore fusione roll undectable rimane al di sotto di 120 ° ... controllare il fusore
Posted on Jun 01, 2010
  • 177 Answers
SOURCE: Im looking for the minolta dialta di 152 driver
Here You Go. :) http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=Di152
Posted on Jul 19, 2010
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Minolta Dialta DI-550 hard drive
Rear of the machine left side mite be covered bye one board
Feb 27, 2012 | Minolta Di550 B&W Laser Printer
Minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
Jan 10, 2010 | Minolta Office Equipment & Supplies
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
C1300 error code
· These malfunctions are concerned with faulty symptoms as they relate to software, hardware, and communications. For remedial actions, change the board, check for cable connections, and turn the Power Switch OFF and ON. (6) C10]] to C13]] C1300 1. Reset the malfunction and turn OFF and ON the Power Switch. 2. If the same malfunction persists, check the harnesses and PJs between PH Unit and PWB-A and, if they are intact, change PH Unit or PWB-A, in that order.
Dec 27, 2008 | Minolta DiALTA Di250 All-In-One Laser...
Problem in networking minolta di 520/620
do you have the optional print controller installed? if not you would need to buy one.
Jan 26, 2008 | Minolta DiALTA Di520 Laser Printer
Master Reset?
Page 147 will show you reseting procedures
http://www.copierprofessionals.com/protectedmembers/130914/DI_450_550/DI_450_550/FIELD.pdf
Let me know if this helps. If not I will keep looking.
Nov 21, 2007 | Minolta Di550 B&W Laser Printer
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
