Question about Aeneon AXT960UD20-25D 4GB PC2-6400 DDR2-800MHz non-ECC Unbuffered
I have EL1600 with 1Gb RAM Can I incrase it 2 Gb, ehat type or RAM I have to buy. As it say in chip 1Gb 1Rx8 PC2-6400U-666-13-D1-800MHZ M2092 100EEx2
That should have worked
2 Gb DDR2 PC2-5300 • CL=5 • Unbuffered • NON-ECC • DDR2-667 • 1.8V • 256Meg x 64 •
or
2 Gb DDR2 PC2-6400 • CL=5 • Unbuffered • NON-ECC • DDR2-800 • 1.8V • 256Meg x 64 •
Jan 22, 2015 | eMachines EL1600-01
I NEED RAM FOR MB 210882
This is the specs for the RAM you require.
Memory
The Dell E210882 system board is compatible with PC2-3200 (400MHz) or PC2-4300 (533MHz) DDR2 non-ECC and unbuffered SDRAM. The motherboard has four slots for memory. Compatible capacities include: 128MB, 256MB, 512MB or 1GB. The maximum installable RAM is 4GB.
Google search the Internet for this RAM
Sep 20, 2012 | Intel Motherboard
CAN I REPLACE THE MEMORY WITH A 4 GIG STICK
this will depend on your motherboard
whether you can install a 4 gb module of ram
you will need to select your motherboard from a dropdown list
also on the left will be types of ram ddr2 ddr3...... you will need to select which type you have
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
NON-ECC/Non-parity - Most desktop and laptop computers take NON-ECC or Non-parity memory.
ECC/Parity - ECC or parity modules look for errors in data and are most often found in servers and other mission-critical applications used by large networks and businesses.
Unbuffered - Most PCs and workstations use unbuffered memory which is faster than registered memory.
hope this helps you
Oct 12, 2011 | Computers & Internet
How to know that the ram can match with your motherboard?
This motherboard supports DDR200/266/333 SDRAM
The memory needs to match one of these numbers so:
DDR200
DDR266
DDR333
one of these types will work
This motherboard will support a maximum of 4GB of memory.
Apr 13, 2011 | ASUS VIA KT333 Chipset A7V333...
I have a m4a78lt-m motherboard will kingston ddr3 1600 4gb khx1600c9d3b1k2/4gx memory work with 32bit os I am putting a system togather have purchased the mother board and memory now i am questing if it...
This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
(Kit of 2) Intel XMP HyperX = DDR3-1600
Default = DDR3-1333 CL9-9-9-27
CL9-9-9 1.65V
1.5V
In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
Jan 28, 2011 | ASUS M4A78LTM LE Motherboard
Ram seems to be bad the computer beeps
this machine requires (up to 4GB) 1066MHz DDR3 SDRAM
2G DDR3 PC3-10600 CL=7 Unbuffered NON-ECC DDR3-1333 1.5V 256Meg x 64, sell for about $30-$40ea
Jan 11, 2011 | Apple 13.3 MacBook Air 1.8GHz 2GB RAM 80GB...
HP EVO D530 black screen after ram upgrade
This means one of 3 things
1. Bad Ram module
2. The Ram module is not plugged in correctly or all the way in.
3. The Ram could be incompatible.
Your PC is compatible the follwing types of ram...
DDR PC2700 • CL=2.5 • Unbuffered • NON-ECC • DDR333 • 2.5V • 64Meg x 64
or
DDR PC3200 • CL=3 • Unbuffered • NON-ECC • DDR400 • 2.6V • 32Meg x 64
Oct 16, 2009 | HP Compaq Evo d530 PC Desktop
Hello! can i use two 1GB DDR2-800 ram in my motherboard INTEL D102GGC2
Your motherboard takes 533 or 400 DDR2 SDRAM Non-ECC DIMMs.
If your memory is DDR2 Non-ECC it will fit but only work at 533.
Jun 17, 2009 | Intel D102GGC2 Motherboard
Memory swap
This is the memory specs for your board 4 x 184-pin DIMM Sockets support max. 4GB unbuffered non-ECC PC3200/2700/2100/1600 DDR SDRAM memory Dual-channel memory architecture
Jun 08, 2007 | ASUS P4S800D-X Motherboard
Aeneon AXT960UD20-25D 4GB PC2-6400 DDR2-800MHz non-ECC Unbuffered Logo
114 people viewed this question
Top Aeneon Computers & Internet Experts
David Payne
David Payne
Are you an Aeneon Computer and Internet Expert? Answer questions, earn points and help others
