Question about Sears Building Materials
Craftsman 13918600 remote control doesn't work. hard wired opener inside the garage works fine. changed the remote battery and have strong red light when pressed. cant find a manual, don't know what the three buttons on the remote do and don't know how to reset ....please help
myob247
  • 1342 Answers
SOURCE: garage door remote won't open the garage door
The little button with a padlock on the wall control is a "vacation" lockout feature that disables the remotes. There should be a small LED on the wall control that is always on steady. When the padlock button is pressed and released the LED should be constantly blinking (indicating the vacation lockout mode is active) and your remotes should be disabled. The wall control will still operate the door. Pushing the padlock button again should make the LED stop blinking and restore the door to normal operation.
Posted on Jun 19, 2008
SOURCE: Garage Door Remote Not Working Consistently
Lift Master Security Plus remote works only intermitenly, It seems to lock after a few tries, Works from inside garage, Seems to lock up after few tries, Wall opener fine. Changed batteries several times. Can't understand why it works and then doesn't. Tried cleaning sensors and wires,
Posted on Oct 29, 2008
SOURCE: Garage Door Openenr Motor Buzz
Look at your manuel find the page that shows the limit access switch. (Unplug your opener.) It isn't really a switch, but the three white plastic screw like parts. The center has a brown wire connected to it, which has a metal piece that is as wide as all three white screws. The outside screws are your limit access stop guides, one for the up control stop guide and the other for the down control stop guide. If the center screw with the metal part gets caught behind on of the stop guides the motor will not engage. Gently move metal piece from behind the stop guide.
Posted on Nov 10, 2008
  • 244 Answers
SOURCE: Problem with my Craftsman 139.53879
when you have to be closer to garage to make remote work tells you battery is going low. Do you have a LOCK or VACATION button. Make sure it is off. May need to recode remotes. See manual for how. Very easy
Posted on Jan 15, 2009
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
Wireless garage door opener works wired one doesn,t
Either the wall control has gone bad or you have a broken wire going to it.
Nov 18, 2011 | Sears Craftsman LiftMaster Chamberlain...
During and after the cold snap here near Ft. Worth Texas the remotes do not open the garage door. I replaced the battery in one with no change. In warmer temps it works fine. The house button always...
If none of your remotes work and they all failed at the same time it is most likely the receiver that has quit. It is part of the logic board. The wall control is hard wired and doesn't use the receiver.
Feb 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Outside keypad will not open or close door,but the control inside works. put new battery in no help
The wall control is hard wired to the opener and doesn't use the receiver. The keypad does use the receiver. If you have hand remotes that work then it is your keypad that has quit working. Without remotes you cannot know if it is the keypad or the receiver.
Mar 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Intermittent remote trouble
Your wall control is hard wired and doesn't use the receiver portion of the logic board. The remotes do. Your receiver is going bad.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
Jul 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Craftsman garage door opener (1/2 hp) - light flashing
most of the time when the lights start flashing on them and they won't work it's something in the way of the eyes that cross the garage at the bottom are something bummed them and there not lining up no more check that first.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote doesn't work!!!
You could try to replace batteries. May be they are stong enough to make the LED flicker, but not strong enough to send out a proper signal to the receiver.
Mar 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
42 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
