A fox A Fox AG31-M2 manual - Computers & Internet
  • 1596 Answers
SOURCE: timing specs for vw fox 1.8
Tune-up Specifications
Air/Fuel Ratio 0.7% Air/Fuel Ratio-Limits[1] 0.3 - 1.1% Timing[2] 6°+/- 1°BTDC Timing Advance[3] 30°+/- 3°BTDC Idle RPM[4] 800 +/- 50 [1] Check CO with the oxygen sensor connected. [2] AT 2300 RPM, and coolant temperature sensor disconnected. [3] Normal operating temperature, with coolant temp. sensor connected, at 2300 RPM. Add initial timing. [4] A/C off.
Timing mark is on flywheel, access hole is on top of bellhousing. Remove access plug with 27mm wrench if necessary
Firing Order is > 1342 Clockwise Rotation & #1 Plug Wire is at 2 Oclock on Distribitor Cap
Align the mark (can be a dot or notch) on the intermediate shaft sprocket with the notch in the crank pulley. Align the mark (can be a dot or notch) on the "Back" of camshaft sprocket with the top edge of the valve cover gasket. Be sure all the timing marks are properly aligned.
For further information refer to Timing Belt : Service and Repair
NOTE : The 8 valve engine requires a special wrench, Volkswagen No. US4493 or equivalent, to adjust the camshaft drive belt tensioner. Whenever the drive belt is removed and refitted, the camshaft and intermediate shaft timing MUST be adjusted. The drive belt can be replaced without removing the belt sprockets.
  1. Loosen alternator adjusting bolts and remove the fan belt.
  2. Remove the water pump pulley bolts and remove the pulley.
  3. Remove the upper timing cover bolts and remove the cover.
  4. Remove the timing belt guide, if equipped.
  5. Turn the engine by hand to set the No. 1 piston at Top Dead Center (TDC) and remove the crankshaft pulley.
  6. Remove bolt and nuts securing the lower timing cover and remove the cover. CAUTION: Turning the camshaft or crankshaft with the timing belt removed may cause damage to pistons and/or valves.
  7. Loosen timing belt tensioner locknut, release belt tension and remove belt from sprockets.
  8. Inspect belt for visible damage such as missing teeth or exposed threads. Inspect tensioner bearing for smooth running. Any damaged components should be replaced.
NOTE : On high mileage engines, failure of the tensioner bearing is a possibility. Consider replacing the bearing when replacing the timing belt.
  1. Align the mark (can be a dot or notch) on the intermediate shaft sprocket with the notch in the crank pulley. Align the mark (can be a dot or notch) on the "Back" of camshaft sprocket with the top edge of the valve cover gasket. Be sure all the timing marks are properly aligned.
  2. Temporarily install the crankshaft pulley to the crankshaft. Fit the timing belt starting with the crankshaft and intermediate shaft sprockets. Fit the belt so that it is as tight as possible between the crankshaft and the intermediate shaft sprockets and between the intermediate shaft and camshaft sprockets.
    1. Turn the belt tensioner clockwise to adjust the tension. The direction is important to avoid contact with the timing cover. Check the tension by twisting the belt as shown. You should be able to twist it no more than 90 degrees.
    2. Tighten the tensioner locknut to: 33 ft lbs (45 Nm)
    3. Rotate the crankshaft two revolutions and recheck the belt tension and the timing marks for proper alignment.
    NOTE: Very slight movement of sprockets and marks can be expected as belt tension is adjusted. Slight movement is OK. The smallest possible increment of adjustment is one whole tooth of the belt or sprocket.
    1. Remove the crankshaft pulley and refit the lower timing cover. Tighten the bolts to: 87 in lbs (10 Nm)
    2. Refit crankshaft pulley and tighten the bolts to: 15 ft lbs (20 Nm)
    3. Refit timing belt guide, if equipped.
    4. Refit upper timing cover and tighten bolt and nuts to: 87 in lbs (10 Nm)
    5. Refit water pump pulley and tighten the bolts to: 15 ft lbs (20 Nm)
    6. Refit fan belt and adjust tension. Tighten alternator adjusting bolts.
    Please Dont Forget To RATE ME !
Posted on Feb 09, 2009
  • 109 Answers
SOURCE: Motor Oil 1989 vw fox
I use synthetic, but that's your choice... I use 10w-30 in winter and 20w-50 in summer
Posted on Apr 19, 2009
  • 773 Answers
SOURCE: Want to build a fox hunt antenna or fox hunt kit
I know some one who has built some really good fox hunt antenna's. However, things of this nature are usually kept secret. For instance, i have known him a while, and he trusts me, but he still will not give me any info on how he has made them.
It will be hard to find any one freely giving this info up.
Posted on Nov 20, 2009
  • 1374 Answers
SOURCE: vw fox lights do not go on despite changing fuses and relays
Try testing the switch and then the relay. Usually its the switch. Use a flat screw driver to pull it s out of there connector. Use a jumper wire and shop manual to jump the terminals and see if the lights come on. If they do its the switch.
The relay you check for continuity and resistance.
Posted on Mar 18, 2010
  • 108 Answers
SOURCE: I can't get FOX on my converter box--what is the
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Posted on Apr 07, 2010
Need mboard driver for afox ag31-m2
HELLO BRO,
YOU CAN DOWNLAOD THE AFOX AG3-M2 DRIVER BY SEARCHING IN GOOGLE.COM
Apr 05, 2011 | Computers & Internet
1988 volkswagen fox fuse box panel
it should also be listed in your manual
Feb 16, 2009 | 1988 Volkswagen Fox
Using * in a EXCEL functions
Correction to your code
=COUNTIF(M2,"*Fox*")
version of formula that will work
=IF(COUNTIF(M2,"*FOX*"),"yes","no")
Jan 08, 2009 | Microsoft Excel for PC
1988 volkswagen fox fusebox diagram
It should also say in your manual
Nov 25, 2008 | 1988 Volkswagen Fox
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
