Question about Coffee Makers & Espresso Machines
La Cimbali M30 Dosatron Manual - Coffee Makers & Espresso Machines
3 Suggested Answers
  • 18 Answers
SOURCE: Hi there we have a la cimbali m30 dosatron and
There usually no fuses on a M30 dosatron unless it's the "L" shaped supplemental supply board which has a small 250V, 6 3/4 A fuse (half the size of a normal glass tube fuse). Most boards use a similar size but rated at 4 amps for the PC board power protection. The only other fuses (older models) have big 10 amp jobs for the main power to the heater elements. But this has been replace with safety relay and or high thermal limit breakers. you should be able to find both at a hardware store. The smaller fuses at Radio shack or electronic store.
Posted on Feb 10, 2010
  • 18 Answers
SOURCE: La Cimbali Owners Manual Wanted
Operators manual only describes how to install and set up. The Technician's manual is translated from Italian and is purposely vague. (Cimbali wants you to go to tech school). Suggest you ask for a annual preventive maintenance from your local service Cimbali dealer. You may need an overhaul/de-scaling which will be very expensive (+$1,000) in labor and parts. (mostly labor as it takes us about 40-50 hours per machine.) Hopefully you just need to change the worn parts in both groups and a vacuum valve. Good luck!
La Cimbali M30 Dosatron Technical Manual
Customer can perform daily (hourly) cleaning and back flushing. Which really helps keeping everything working smoothly. Even if the back flushing is done hourly without cleaning powder helps. The best practice I've observed was clearing group(s) after each dosing. (when customer's order is done)
Other function adjustments may require a service key and tech.
ukeboy57
Oct 17, 2013 | Espresso RMI La Cimbali Espresso Machine
La Cimbali M30 Dosatron Espresso Machine dosing buttons not functioning, how do I fix?
These are membrane pads that do require a full replacement as they are all attached on a sheet. Some of the optional buttons are on separate pads but still grouped together.
check cimbali.com (for current USA contact)
Dosing can be change though some machines may require a service key.
you can also try (which is closer to your time zone)
Hawaiian Paradise Coffee 808) 682-4422
ukebo57
Jan 25, 2013 | Espresso RMI La Cimbali Espresso Machine
Hello, i have a cimbali m31 dosatron. for the electronic part there is a 10-pole cable which came off the plastic part. now i dont know in what order to put back the 10 single cables. can anyone help me...
STOP! There is 220 Volts and water in this machine. Please call for service. check with cimbali.com for current contacts,
Ribbon cables only go on one way.
ukeboy57
Aug 08, 2011 | Espresso RMI La Cimbali Espresso Machine
La Cimbali M39 Dosatron Maintenance Manual
La Cimbali M39 Dosatron Maintenance Manual please send me. hari.644@gmail.com
Dec 22, 2010 | Microwave Ovens
Hi there we have a la cimbali m30 dosatron and someone has pulled out all the fuses on the pc board and we need to know what sizes they are to replace them. Thanks Simon
Oct 21, 2009 | Espresso RMI La Cimbali Espresso Machine
I'm looking at a m30 Dosatron D'Italia coffee machine.
Get it. It is hard to find a Cimbali on the market for a great price. The M30 might be about 6-8 years old. There is nothing on there that you cannot fix yourself.
Jun 16, 2009 | Espresso RMI La Cimbali Espresso Machine
I have La Cimbali Dosatron M20, working perfectly, i have only 1 problem. Dosing of water for cups, i want to change but i dont know how. i would apreciate if you can help me. Regards, Sulejman Sulejmani
Hold down the stop button for 8-10 seconds or until you hear the faint beeping sound, press button to program when you get the correct level press stop button. On some models you have to hold the button until you get the correct level then release. When you are done programming press stop button a second time to exit program mode.
Mar 26, 2009 | Espresso RMI La Cimbali Espresso Machine
Mar 13, 2009 | Espresso RMI La Cimbali Espresso Machine
Coffee Makers & Espresso Machines Logo
48 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
