Question about Mr. Coffee JWX27 12-Cup Coffee Maker
Heating element replacement
Green lites come on, unit doesn't start up
  • 210 Answers
Yes, it does sound like the heating element needs to be replaced. However, this coffeemaker is not built to be serviceable in that regard.
I recommend replacing the coffeemaker.
In the future, make sure you do not add water to the reservoir unless the coffeemaker has been turned of for at least five minutes. This will help prolong the life of the heating element.
The heating element will naturally degrade over time. But, it can incur sudden damage when the reservoir is refilled with water too soon - while the element is still hot. Because of the simple design, if the coffeemaker is on, then both the warming plate's heating element and the reservoir's heating element are on. So, after a brewing cycle is complete, the reservoir's heating element stays on. Without any in the reservoir to keep it cool, the heating element superheats. So, if water is put in the reservoir while the coffeemaker is on or before the element has adequately cooled, the sudden burst of steam from the water contacting the element can be quite violent.
Posted on Oct 25, 2014
Unit not generating heat -
More in likely heating element has failed and needs to be replaced...
Mar 04, 2015 | Heating & Cooling
Electrolux ewt 10410W
HEATING ELEMENT RELAY FAULT... THAT'S ERROR CODE ON YOUR MACHINE
Dec 27, 2013 | Washing Machines
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Gateway 500C: Dead. green PSU lite doesn't lite when pressing test switch
Obviously your Power Supply Unit is dead. You just have to replace it.
Feb 17, 2013 | Gateway Computers & Internet
Hi Don
first thing to check would be all power leads and fuse to clear those areas from the list. Providing all of these are correct, it looks like either your power button has gone faulty of the power supply itself. I am not familiar with this particular machine, is it a normal tower sized machine? if so then a psu replacement is relatively cheap and easy, just make sure that the replacement has all of the connections that you require.
Kenmore 65882 .. replaced heating element .. still doesn't heat .. is there a reset button??
Bummer, it is almost never the heating element. Check breakers, F U L L Y turn it off, forcefully so, and test again. Then look into the thermal limiters, and their connections, then look into the contact in the timer....
PLEASE remember to unplug the unit before any servicing or testing.
Jul 04, 2011 | Kenmore Dryers
Polohunt1@aol.com my bionaire bch9221 120 volt heater does not produce heat anymore.....i'm thinking that maybe an element within the unit is burned out.
Mine was doing the same thing. Took it apart and found that the white wire which hooked up from the circuit board to the heating element had burnt which broke the connection...hence no heat....replaced burnt wire and resoldered to heating element...put it back together and voila I have heat once more....still doesn't solve why the wire fried though....
Oct 13, 2010 | Bionaire Heating & Cooling
I have done the normal wash heated dry method and
This would mean there is a failure in the unit most likely of the heating element, if the water does not heat the light will blink
Apr 21, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Mr. Coffee JWX27 12-Cup Coffee Maker Logo
585 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
