Question about Toshiba 23HLV85 Television
Mother lost the remote. Trying to get tv on channel 3
I lost my remote and can't put my tv on channel 3 so I can watch cable tv
If there is no menu button on your TV's front panel, you can't select this option without its remote control.
Aug 26, 2012 | One For All URC4220 Remote Control
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
NEED CODES FOR RCA CONVERTER BOX TO PROGRAM TV TO REMOTE
Good day,
I might be missing something here, but if YourTV has the basic controls on the TV itself, such as on/off volume, and channel select, then just turn on tv, and set it to channel 3.
Use your converter box remote to scan for channels, and other options it has as needed.
Jan 23, 2010 | Televison & Video
Lost channels on a Sony KV-1972R
Go to menu and select add/delete channels. Then select 02, or 03. Some channels that are selected the numbers will show green, channels not locked in will be red.
Jan 18, 2009 | Televison & Video
Lost Remote
usually on some tv s you can get the channel 3 from the MENU of tv , what I can help you with now is the link so you can purchase the original remote , heres the link :
http://remotes.com/store/sylvania/6520fdg.html , hope this helps AJ
May 14, 2008 | Sylvania 6520FDG 20" TV/DVD Combo
Remote control codes
how do activate sharp tv to a comcast remote to change the regular channel on he tv im trying to turn to channel 3 but when i turn from the tv it skip from 2 to 5 then so on.
Feb 19, 2008 | Televison & Video
Stuck on channel 3
Set-up in menu = step thru each page = skip what does not
apply to you = get to auto-program....be sure signal is attached
to set first.........................T.
Dec 11, 2007 | RCA F32650 32" TV
GE TV model 25gt239
i have one , to watch DVD or VHS by the audio Video Compenent, from your remote control pess ( 00 ) 2x zero, thanx.
Nov 25, 2007 | Televison & Video
Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Sep 22, 2007 | Sharp 32R-S50 32" TV
Problem with Orion TV Receiving Signals
Try an original replacement remote (www). 2)solder or replace IR detector 3)send to shop for o'scope analysis.
Aug 08, 2007 | Orion1934 19" TV
Toshiba 23HLV85 Television Logo
18 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
