FixYa.com
Tags:
BenQ Joybook 3000-01  PC Notebook
Benq Joybook 3000 Keyboard Issues
posted by Scorpion70 on Sep 26, 2007
I have abenq Joybook 3000 and for soem odd reason when I press certain charachters it displays something else.
For example I type B it displays BVF..I type M it displays MN and when I press the space bar it displays C.
Can anyone help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Oct 03, 2007
Not Rated (0)
Blue Hammer
Rank:Wiz Wiz
Rating: 76%, 123 votes
There are several extra function keys on your laptop.
Something like "Fn" is common to most of the notebooks, and is used to control secondary fuction of a key.
You will see keys marked with other than the ordinary alphabetic letters. These are the secondary fuctions.
The purpose of all the secondary keys are explained in the manual that accompanies your laptop.
you may have pressed a key combination unknowingly as a result you see this problem. Pressing the same combination will revert it back to normal operation.
You should also check the key contacts are free from dust and other particles. If some thing like milk or water is spilt on it, then it is normal to get these problems, ultil it is cleaned.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PC Laptops problems?
PC Laptops
problem in wireless
wireless intenet disconnect... Answer This...
PC Laptops
scroll up/down function
the scroll up/down function in... Answer This...
PC Laptops
Memorystick duo
My Acer Travelmate is supposed... Answer This...
PC Laptops
Gateway MX6453 or MA3
I've had the same problem with... Answer This...
PC Laptops
pavo
pomagajte molim vas!!!!... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
