Question about JVC HR-XVC33U DVD Player/VCR
JVC HR-XVS44U - DVD tray won't eject
We've recently had a problem that the DVD player will not eject the tray and the VCR tends to keep the tapes until we've turned off and on a few times. Remote works, appears that all other buttons react, just can't get deck to release. I can't see where there might be an emergency release either to see if someone may have gotten something stuck, but when we push the button there isn't any reaction even that it's trying.
  • 1 more comment
  • gazelle29 Nov 02, 2007
    My DVD player and VCR will not eject at all anymore. This has been a problem for awhile now and I use to be able to unplug it and let it cool off for a minute then plug it back up and it would finally open to let the dvd out or the VCR tape, but it won't do it anymore, so I have a tape and a dvd stuck in the unit.
  • jcampbell6 Dec 29, 2007
    Ditto to most of the above. First only the DVD tray was stuck and the VCR functions and eject worked normally. Now both transports will not open/eject and the unit will not turn off via either the remote or front button.
    Only the VCR configuration functions seem to be accessible. The unit will switch between VCR and DVD but does not seem to recognize any DVD commands. It would seem that the "sticking" of the DVD deck has made the entire unit's logic to go into some strange unrecoverable mode.
    If there was a mechanical release (open) on the DVD deck that might reset the unit and restore it to a known state but I cannot find one.
    Physical power down and up for short periords do not seem to clear or reset anything either. I am not sure how long this unit will retain memory settings on a physical power down.
  • lwall11 Jan 18, 2009
    I own 4 HR-XVS44U
    units. 3 of the 4 have died the same death. a bench tech at work says
    it is a power supply problem. I am going to change the ventilation in
    my one remaining unit in hopes of not cooking the last unit.
There are several capacitors in the power supply that fail and give this fault.
Posted on Sep 05, 2008
SOURCE:
DVD region hack available?
no such thing exists
JVC HR-XVC1U region code - VideoHelp
www.videohelp.com/dvdhacks/jvc-hr-xvc1u/1143
  1. Cached
DVD Hacks > JVC HR-XVC1U region code hack. ... What are Blu-ray and DVD region codes, country codes, multi-region or zone locks? Read DVD Player ...
DVD Player and Blu-ray Player region codes - VideoHelp
www.videohelp.com/dvdhacks?dvdplayer...hits=25&listall...
  1. Cached
What are Blu-ray and DVD region codes, country codes, multi-region or zone ... 12382 DVD Hack hits, Showing 3276 to 3300 DVD Hacks ... JVC HR-XVC1U
JVC HR-XVC1U DVD Player/VCR Multi region hack ... - Fixya
www.fixya.com > ... > JVC > JVC HR-XVC1U DVD Player/VCR
  1. Cached
multi-region code hack is there a multi-region code hack for a Toshiba SD 370E dvd player? Can you help? I need the multi region code for my Toshiba DVD ...
JVC HR-XVC1U DVD Player/VCR Hack - Questions - Fixya
  1. Cached
will not play all regoins You need to hack the player to get all regions. There are a lot of web sites tthat carry the information you require. Some models dont hack ...
JVC HR-XVC1U - DVD Players - Retrevo
www.retrevo.com > Blu-ray / DVD Players > JVC Blu-ray / DVD Players
  1. Cached
JVC HR-XVC1U: No region hack for this player. Post region code/hack here. ... Harmony 880 w/ JVC HR-XVC1U VCR/DVD Combo- Help - Logitech Forums.
JVC HR-XVC1UC - DVD Players - Retrevo
  1. Cached
Learn more about the JVC HR-XVC1UC before you decide to buy. Download User ... www.videohelp.com. JVC HR-XVC1U: No region hack for this player.
May 03, 2016 | JVC HR-XVC1U DVD-VCR Combo
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
My jvc dvd player/vcr will not eject disc says its reading but wont play or eject
You might want to check the thin ribbon cables attached to the dvd inside the unit, pull them out and slip them back in.
Nov 24, 2009 | JVC HR-XVC27U DVD Player/VCR
Repeat recording 5x week for same show
Found the solution in the on-line manual, around p. 33. Thanks.
Aug 14, 2009 | JVC HR-XVC20U DVD Player/VCR
I have a HR-J625EA JVC VCR & video cannot be ejected.
this sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Dec 08, 2008 | JVC HR-S9800 S-VHS VCR
Recording from tape to cd
you can't, it is only a dvd player not a dvd recorder
Nov 28, 2008 | JVC HR-XVC1U DVD Player/VCR
JVC HR-XVC30U DVD Player / VCR
This model is a DVD player not a DVD recorder. Only the VCR can record.
Sep 03, 2008 | JVC HR-XVC30U DVD Player/VCR
DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
Oct 18, 2007 | JVC HR-XVC19S DVD Player/VCR
JVC HR-XVC33U DVD Player/VCR Logo
1,107 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
