Question about Brother GX-6750 Typewriter
Fix character spacing - Brother GX-6750 Typewriter
    Sergeant:
  • 329 Answers
Most brothers have a slide switch or code that allows you to choos 10 - 1 2 - 15 or sometimes proportional pitch. You need to match up to what printwheel you have in the machine, the printwheel will have iton the wheel, mos common is 10 spaces per inch or pica, or 12 spaces per inch (elite)
Posted on Oct 28, 2013
Volume label
Put your drive into a USB port; right click on that drive after it appears in My Computer and select Properties. On the "General" tab, change the label text in the field at the top and click OK to save your change. You have a limit of 11 characters and stick with letters and numbers (spaces are not allowed but you can use an underscore character "_" instead or a space character).
Aug 15, 2014 | Kingston DataTraveler 101 G2
Tip
Prinshop 23 Deluxe, fix character banner display in calendar
This is a fix easier explained than titled...
When using Calendar Creator in Printshop 23 Deluxe you can add multiple events across multiple days. But while a single event can use box, when adding multiple events it cuts off the message so many use banner to get them in the box for that day. The problem is that when you print, although the box event prints fine, the banner events will cut off part of the last character on the right side. This effects any character including space, so to fix this; just add a space at the end of each event you're importing.
on Mar 22, 2010 | Computers & Internet
How do you add a space between words (character space) on the Ellure?
The space is the icon that looks like underline. There is no underline
May 10, 2014 | Baby Lock Ellure
Error message 1324. The path My Pictures contains an invalid character. Version 2.5.2.36 Can I remove? Can I update so my Quickbooks program can update? Need help please!
There are 3 possible reasons why you are getting this error message:
1. An invalid character in QuickBooks installation path.
2. An incorrect path setting in the Windows registry.
3.Insufficient hard drive space available to install the QuickBooks program.
To fix this problem, please do the following:
  1. Restart your computer, and reinstall QuickBooks.
  2. Confirm that at least 2.5 GB of disk space is available for installing QuickBooks (Quickbooks 2010 requires 1.5GB of disk space):
    1. Double-click the Computer (for Windows 7 or Vista) or My Computer (for Windows XP) icon on your Windows desktop.
    2. Note the amount of free space shown in the window next to the drive letter where QuickBooks is being installed:
      • If the amount of free space is less than 1 GB, free up disk space before installing QuickBooks or install QuickBooks on a different drive.
      • If the amount of free space is greater than 1 GB, proceed with step 2.
  3. Remove invalid characters from the QuickBooks installation path:
    1. Right-click the Windows Start button and select Explore.
    2. Navigate to the path shown in the error:
      • If there are non-alphanumeric characters in the name of any folder in the installation path, right-click the folder and select Rename to remove them, and then reinstall QuickBooks.
      • If there are only alphanumeric characters in the installation path, proceed with step 3.
  4. Create a new user in Windows to rewrite any Windows registry settings that may be causing the error and log in as that user to install QuickBooks.
Note: You must be logged in as a Windows administrator or as a member of the Administrator group to add a new user.
If this solution does not resolve the issue, you can read discussions and post messages and questions relating to your issue on the Intuit QuickBooks Community site for free, or you can contact a technical support agent for additional guidance. Fees may apply.
Nov 30, 2012 | NTI Backup Now EZ
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
Spacing between words
I have the Model 600. In the characters, there is one that looks like an "underline". Actually, it allows a space between words and does not make an underline mark. Some of the embroidery machines use that character to allow a space between words instead of having a "space" character.
Dec 27, 2009 | Bernina Bernette Deco 600
10 pt printwheel printing 12 pt spacing
Some type styles do have thinner print than others. The pitch is automaticly selected when you change printwheels. You can measure the pitch by printing 12 letter "i" and putting a ruler up to it.
12 spaces per inch is elite and 10 is pica.
Nov 19, 2008 | Lexmark Wheelwriter 1000 Typewriter
Brother GX-6750 Typewriter Logo
53 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
