Question about Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair
Getting gas and spark but wont crank - Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair
  • 2,113 Answers
You may have a bad starter... or a bad battery. But what if you don't have the vehicle all the way in park. Try starting the vehicle in neutral. If you hear the solenoid clicking then it must be a low battery. If you hear a strong click then the starter is bad
Posted on Oct 18, 2013
2003 spectra was running good when i parked it but now it wont start it cranks over but wont start
I would check the spark sometimes coils go out when they get hot then cool.
Feb 01, 2015 | 2003 Kia Spectra
I have a 2001 grand caravan 3.3L v6 has spark and is getting gas but wont start . what could be causing this?
If your Injectors has a fuel during cranking your engine, check your spark plugs if it is wet dry it up, or change it by new ones. Then crank it again.
Jan 01, 2015 | 2001 Dodge Grand Caravan
My truck ids getting gas and fire cranks but wont start
See if your getting spark,If not its probably the crank or cam sensor.
Aug 21, 2014 | 1991 Chevrolet S-10
It will turn over but wont crank
Not starting issues are usually spark or fuel problems. If you have gas getting to the carb then check your spark. First check all the wire connectors and plug wire to make sure everything is connected. If you find a loose connection fix it then try it. If not, then remove the spark plug but leave it attached to the plug wire set it on the cylinder head and turn the engine over. You should see a bright spark. If you have a really weak spark or none at all, then it may be your ignition coil or a related ignition part.
Jan 28, 2014 | kawasaki 2006 Bayou 250
1988 mercedes 260e wont start.
If It Turns Over REAL Fast not Skipping a Beat - Possible Timing Belt !
Try Crank Senser First
Dec 11, 2013 | Cars & Trucks
My 2000 Chrysler 300m wont start it turns over but wont fire its getting gas but wont fire
Are you certain it's getting gas, does it smell flooded?
Pull one of the plugs, see if its wet after cranking.
Ground plug and check for spark, if no spark, problem could be crank sensor or coil packs.
Aug 30, 2013 | Chrysler Cars & Trucks
Cranks but doesnt start
I am a self emplyed mechanic, if a motor cranks but does not start, that is not a starter, you need to see if you have gas or spark . is there a buzzing in the gas tank when you turn the key. if so then you have gas. now you needto see if you have spark. need 2 people to do this . pull a spark plug wire and stick a screw drive in the boot and crank the motor please stand back,and look for spark. if you have spark. then you need a crank position sensor thank you ted
Sep 08, 2012 | 2004 Dodge Stratus
My yy50qt6 scooter wont start
mine wuz running fine i shut it off at the store and havent got it to crank since
Jun 04, 2012 | Motorcycles
Cranks but wont start
Check for spark and gas. Try to add gas to the intake. If it starts, there is a fuel delivery problem. If it doesn't, then there may be no spark which you can test using a spark tester.
If there is no spark, the crank sensor circuit may be at fault.
Dec 12, 2011 | 1992 Ford F350
91 honda accord wont crank
There is a sensor under the left hand side of the dash that would not allow it to start, provided that you have replaced the electronic spark module inside the distributor first, which is what it sounds like it would be, When you say you replaced the distributor I assume you replaced it complete!
Jun 12, 2010 | 1991 Honda Accord
Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Logo
62 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
Robert McCall
Robert McCall
 Russ Hill
Russ Hill
Joel C.
Joel C.
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
