Question about Sansui Audio Players & Recorders
I have a Sansui 2000A Stereo Tuner Amplifier that has stopped putting out sound. The left and right 2.5 amp fuses look OK but the fuse all by itself to the right of the B speaker connections labeled as 100-127V - 3A 220-250V 2A (which had a 2A fuse) was blown. I put in a new one and power comes on but I have no sound. Are there other fuses in the unit? It was working fine but it only gets used a couple times a year.
  • 156 Answers
SOURCE: No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Posted on Mar 16, 2007
  • 752 Answers
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
Posted on Oct 13, 2007
  • 236 Answers
SOURCE: Sansui 3200Z stereo receiver --
now you have to try and isolate frist your problem .is it your speakers? your cabling or your receiver? check all your cables for any loose connections. check your speakers for possible damage, you can try using another set of speakers to your receiver and see if it does the same thjing and wont work. or try also your speakers in another set of receiver.
Posted on Jun 19, 2008
  • 3 Answers
SOURCE: Pioneer Stereo amplifier SA-7800 sound problem
reach me at my email for to fix pioneer amplifier 7800
Posted on Sep 11, 2008
  • 631 Answers
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Nov 02, 2008
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
Sansui A200 amplifier dead right channel
Usually is a capacitor or diode blown open up the amp and look for any burnt marks on the motherboard
Feb 07, 2014 | Sansui Audio Players & Recorders
I have a Sansui 2000A Stereo Tuner Amplifies that powers up but has no sound. the fuse for the 220-250V 2A was blown and replaced. The speaker fuses look good. Should I replace them too or is there...
If the fuse was blown on the 220-250 V side, I am assuming that you are in the UK, if you aren't , but are in the US, change the power setting dial/switch on the back to 100-120v and you might be good to go. Also, I know this may sound silly, but make sure that the speaker selector switch is pressed in or set to a speaker set ( A or B). Love the Sansui gear, have many complete systems myself!
Oct 17, 2013 | Sansui Classic Vintage 2000a Stereo...
Best Buy installed new stereo in my 1996 Z3 - Now my stereo stops playing when I put the drivers side window down. My car recently started blowing a fuse.'s been almost 4 years since I had the...
:o( you're going to have to pull the radio out to see what they did. They probably added a wire to an inappropriate circuit to power the new radio or amp. I will paste your factory wiring colors below. If you now have an extra wire, that is the likely culprit. Trace it to see where they hooked it in. If it isn't going to the the fuse box and using an extra slot, make it so by connecting it to the cold side of the fuse and put an approprite size fuse in. To determine the fuse size to use, you can compare the wire gage to other cold side wires and use a fuse the same size as you see being used for similar gage wires. Let me know if you have more questions.
1996 BMW Z3 Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Gray/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Car Stereo Amplifier Location: Passenger Kick Panel
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Yellow/Red
Left Front Speaker Negative Wire (-): Yellow/Brown
Right Front Speaker Positive Wire (+): Brown/Black
Right Front Speaker Negative Wire (-): Blue/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Black
Left Rear Speaker Negative Wire (-): Yellow/Brown
Right Rear Speaker Positive Wire (+): Blue/Violet
Right Rear Speaker Negative Wire (-): Blue/Brown
Oct 26, 2010 | 1996 BMW Z3 Roadster
I just bought a 98 concorde lxi and no sound coming out of the speakers, radio comes on and shows channels just no sounds
Hello georgouseyes,
The problem could be in the output from your receiver to the amp or in the amp itself.
First check to see if the amp powers up. If it doesn't, check the main power fuse (usually located under the hood near the battery). Also check the power and ground connections on both ends.
If the main fuse checks OK, check both onboard fuses. There's 2 35A fuses on the far right.
If the amp powers up OK and the onboard fuses are not defective, it's possibly the output from your receiver or line output converter. Replace the RCA cables with a known good pair. If there's still no sound, I'd suspect that the amp itself is defective.
Hope this helps.
Oct 17, 2009 | Infinity 475A Car Audio Amplifier
I just need to know if the 2 channels from the amp go to the front or rear speaker location on the stereo and if they go to the rear do I hook up the rear speakers directly to the amp and the fronts to the...
The only thing that hooks to the stereo are a remote cable should be labeles on the amp. and the rca cables (red and whites) the different channels go to different sets of speakers.right to right left to left. make sure your amp is grounded well or you'll throw the fuse. Hope this helps if you have questions contact me.
Mar 08, 2009 | Sony NTX-2135 DHD 2 Channel Car Amplifier...
Cant figure how to hook my stereo up
what to remember is pre-amp is before the amplifier then the amplifier to the speakers, go this route, Tuner for radio? from the radio tuner out go to the pre-amp tuner input, then from the pre-amp OUT go to the AMPLIFIER IN, tuner, cd, dvd, tv, any source, if you are using a 2 channel amp and pre-amp this is relatively easy, a little more detailed for multi-channel pre-amps and amps but follow the same path, sound source signal ie. tuner to pre-amp, pre-amp out to amplifier and speaker hookup to amp channels,
Jan 29, 2009 | Audio Players & Recorders
Radio on but no sound
i have a 1994 eagle vision, with the premium sound system (infinity) and yes you do have a amp in your car if you have that sound system and its in the trunk of your car to the left while looking at your trunk from the back of the car :) also if you tryed putting in diffrent speakers other then stock thats your problem you have to rewire new speakers cant use old wiring because it goes threw the stock amp and for some reason the stock amp only works with the stock speakers :P
Oct 01, 2008 | 1995 Eagle Vision
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
Mar 16, 2007 | iLO XM-MP3-CD Car Stereo
35 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
