Question about Health & Beauty
Diagnostic codes cosco scooter - Health & Beauty
It won't move when battery is fully charged
only guessing but today I fixed one with this problem by spraying the speed potand connectors under the top with radioshack contact cleaner/lubricant.now scooter runs fine .
Dec 26, 2013 | Cosco Juvenile Cosco Ability Care 4 Wheel...
Key for cosco mobility scooter
Good day,i suggest you ring a Local Repair Shop & I am sure they will fix you up with your needs.Have a nice day,hope this has helped.Colin
Jun 19, 2013 | Health & Beauty
My cosco scooter is showing fully charged all green but when I push the foward it will not move and the light is flashing
try taking the top off steering and spraying the speed pot and all connecters with contact cleaner/lubricant from Radioshack.I did this today and now the cosco scooter runs real well.
Nov 16, 2012 | Cosco Juvenile Cosco Ability Care 4 Wheel...
Need a new battery
it probably takes 2. we just got some from www.baterysharks.com
Sep 02, 2012 | Cosco Juvenile Cosco Ability Care 4 Wheel...
I need a new seat for this scooter. can I buy one somewhere?
try ebay, or better stil try 'Brighter future workshop' which is a charity in manchester (I think its in Manchester). they supply second hand stuf with excellent knowledge and service plus friendly. hope that helps
Jun 17, 2010 | Cosco Juvenile Cosco Ability Care 4 Wheel...
Won't move lite on battery fully charged
I had this problem with the Cosco 4 wheel scooter. It turned out that one of the primary power lines under the shroud (back housing cover) was loose. It was not disconnected -- just loose. Apparently the loose connection would support enough current flow for the diagnostic circuit, but not enough to move the scooter (similar to using too small of a wire gauge in its effect). Once the power cable connector was tightened down so that the cable would not rotate on the connector, everything worked correctly.
The same symptoms could also be caused by a faulty power cable. If you have access to a multimeter, test the resistance along each cable path. If a path has an unusually high resistance, compared to the others, start to look for problems there.
Apr 16, 2010 | Cosco Juvenile Cosco Ability Care 4 Wheel...
Health & Beauty Logo
23 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
