Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Problems
I have a Whirlpool Calypso approximately a yr to year and a half old and have no power. I've tried unplugging/ and waiting / different outlet, the door opens and I hear a click assuming the lid switch is O.K. Any help would be wonderful
  • bjooones Dec 25, 2007
    No power to control panel. Are there any fuses inside? I can troubleshoot electronics and circuits but havent yet.
  • 447 Answers
Make sure the outlet has power, if it does then you have a control board issue or possible wiring problem inspect/test control board input voltages
Posted on Sep 27, 2007
SOURCE:
My whirlpool was stuck on the Lock switch. we used he cancel button but now it wont run. the fill light come on but nothing happens. I have tried unplugging it to reset the panel, but nothing helps
Double check there is power at the outlet. If no power, check circuit breaker box. If the circuit breaker "pops" after resetting, you have a serious electrical problem in the washer or wireing to the washer. Consider the age of your washer, cost to find a lightly used working replacement, vs the cost for repair tech. Ask for an approximate repair visit cost.
Jan 20, 2015 | Whirlpool Washing Machines
My 6 year old Whirlpool Calypso washing machine was almost finished with the cycle, when it stopped -- with the error "CE" (Communications Error). I tried restarting it numerous times and the error...
I dont have a solution but mine is 7 yrs old and doing the EXACT same thing. I have had nothing but issues w this washer since I purchased it. Hope to find the answer w/o calling a service man for 500.00 :)
Good luck..Sorry, I had to vent :)
Oct 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer stops/runs every 5 - 30 seconds in the middle of any washing cycle. No error codes. It just stops and than runs again all the time and cannot finish any washing cycle. It is 8 years...
I had the same problem. The washer control board has an intermittent failure. If you unplug power for about 30 minutes then plug it back in you will get a PF code (power failure). Ignore this code and push start again. It may run till it finishes the cycle or it may start cycling again right away. A new board costs about $180 at repairclinic.com
Aug 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
Control board malfunctioning.
You can try tripping the breaker a half dozen times or so, or else leave it unplugged/without power for a couple days. Once it is plugged back in you may have to leave it overnight and then try it, but that almost always revives it. I notice the problem when I don't use the washer/dryer once a week or don't push any buttons during that time to activate it in some way. Problem seems to occur more frequently in the winter when house is cooler.
Feb 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer it seems to be stuck on the ultra hand wash. the only button that does anythinbg is stop. i have unplugged it time and again, but nothing changes
keep it unplugged for at least a half hour -- if nothing solves it you probably need a new board. Ours is going the sidewalk on junk day because of this. Have had it 7 years and more than a dozen service calls on it. Have had the board replaced 2x and the pump 4x -- other calls were techs trying to figure it all out. Garbage machine.
Oct 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We went camping for 2 days came home and the calypso washing machine won't start. We ran a load the day we left with no problems. The outlet works fine, we even tried plugging it into another outlet just...
The same happened with my Sears Calypso machine. The common problem is the front display panel. If you are able to find one at a very good price, post it here.
Aug 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Why is the code cl still showing up even with NO clothes in washer
Try unplugging the washer from power, and wait 10 minutes. Then plug back in. See if this will reset the computer.
Jul 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
325 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
