Question about Scuba Diving & Snorkeling
Compass repair - Scuba Diving & Snorkeling
What is calibrate compass on 2004 Buick Rendezvous
Manual Compass Calibration If the compass appears erratic and the calibration symbol does not appear, you must manually put the compass into the calibration mode. To get into this mode, do the following: 1. Turn the ignition on and cycle the DIC to the compass/temperature mode. 2. Press and hold the SET button for longer than three seconds. ZONE # PRESS & HOLD SET TO CHANGE: This display mode will be displayed when you are manually calibrating the system. The current zone number for compass variance will be displayed in place of the # symbol. Use the SET button to select the zone number from the graphic shown to select the current area of the country that you are driving in. PRESS SET TO CALIBRATE COMPASS: After selecting your zone, press the MODE button and this will be displayed on the DIC. Press the SET button and complete three 360 degree turns in an area free from large metal objects. The following two messages will toggle in the display until you calibrate the compass: • DRIVE VEHICLE IN CIRCLE • CALIBRATING COMPASS When calibration is complete, the display will return to its normal mode. 3-61 info obtained from MANUAL OWL
press the helpful button and follow me on fixya for more tips
Compass Variance Zone Procedure DIC Compass Driver Information Center DIC...
http://www.manuals365.com/swf/buick/2004_buick_rendezvous_owners.html?page=200
http://repair.chiltondiy.com/Buick/Rendezvous/Repair-Manual-Online
http://www.repairservicemanuals.com/Buick
Feb 02, 2016 | Buick Cars & Trucks
What is calibrate compass on 2004 Buick Rendezvous Vous
2009 fusion SEL has data compass error after being rear ended and a shop did repair.
WHAT IS A COMPASS ERROR FOR A 2009 FORD FUSION ...
www.fixya.com/cars/t16705785-compass_error_2009_ford_fusion
Feb 21, 2013 - WHAT IS A COMPASS ERROR FOR A 2009 FORD FUSION A MESSAGE COMES UP ON MY DASH SAYS COMPASS NO ... SOURCE: I HAVE A2009 FORD FUSION AND IT'S NOT GOING OVER 20 MPH ... Compass data error -- how do i determine my zone-- ... Jan 28, 2010 ' 2007 Ford Edge SEL Plus.
Compass - Ford Fusion Sport - Ford Fusion Forum
www.fordfusionforum.com/topic/9390-compass/
Jan 23, 2013 - Compass - posted in Ford Fusion Sport: 2011 Fusion SEL without navigation screen. Following windshield ... I have recalibrated and reset the compassaccording to the manual instructions (several times) but cannot correct the error. Can anyone help? ... picture of where it is: 2009-08-30_051718_2.gif.
Nov 08, 2015 | 2009 Ford Fusion
How to get rid of a large bubble in my compass
Very difficult. See the annual index of Wooden Boat Magazine.
Jul 09, 2014 | Silva Ranger Series 515 Cl Compass
When is a compass in need of repair?
    • 1.
      When there are cracks in the dome.
      2. When fluid levels are low,
      creating a bubble or fluid is all together empty.
      3. The dial or card is
      discolored or yellow.
      4. When the dial begins to stick
      * follow these steps to test dial.........
      While dockside take note of the compass heading. Hold any magnetic object
      to the compass so that the original heading is deflected about 10degrees.
      Remove that object, and see if the dial returns to it's original
      heading.
      Repeat this several times deflecting the compass to both sides.
AdChoices
Jul 09, 2012 | Camping, Backpacking & Hiking
Need to repair a electronic compass in my 99 ford explorer ,the compass and the temperature reader are not working
I offer a repair service for this unit. Check out www.autoclockrepair.com drop me a note if you have any questions, thanks!
Aug 25, 2010 | 1999 Ford Explorer
The dampening fluid has leaked out of my compass. Can it be repaired economically or should I just replace it?
Hello, no it wouldnt be cost efficient to repair. A replacement if it is in a console will not cost a fortune. Hope that helps
Oct 17, 2009 | Compass Scuba Diving & Snorkeling
The bezel on the compass of my Mission Puck 3 fell off during a dive. Is it possible to get a replacement. If not, where can I find the compass module?
Any dive shop worth their salt will be stocking all the major brands, Mares among them. It's possible the bezel can be repaired if there are no leaks or cracks in the compass body. Send it back to them and get an estimate to see if it's worth repairing or replacing.
Sep 05, 2009 | mares Mission Puck 3 Computer Console...
The compass light is not on.
This is a very common problem with many of the mid 2000 Ford truck and SUV overhead consoles. The console is very prone to internal failure. If the dome lights work but the compass unit does not then it is a faulty computer unit. I offer a reasonable repair service with a lifetime guarantee, check it out: www.autoclockrepair.com
There is a bunch of useful info there. Drop me an email if you have questions, thanks!
Mar 23, 2009 | 2000 Ford Explorer
Light for odometer/compass/outside temp doesn't work
I CAN REPAIR THIS PROBLEM WITH 2004-2008 FORD F150 ODOMETER COMPASS OUT I WILL REPAIR FOR $125.00
BRIAN'S SPEEDOMETER @479-652-2258
Feb 19, 2009 | 2005 Ford F-150
Scuba Diving & Snorkeling Logo
89 people viewed this question
Top Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you a Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
