PS BN64-00807B - Televison & Video
What does PS mean
Ps can be alot of things ... Ps -Adobe Photoshop on Pc's ...Ps- post scriptum or after letter or i forgot to write this but ...in a letter ..
Oct 23, 2014 | Crochet World Christmas Crochet Holiday...
Pickup leaks ps fluid from the reservoir changed ps pump and cap still leaking any ideas
Check valves on steering box. What is happening is that the pump is returning more fluid to the reservoir than what it is using to move the box.
Apr 06, 2013 | 1992 Toyota Pickup
Help free activatio code for speed up my pc 2011. Thanks
Here are some activation keys for speed up my pc:
PS-00YWAH-M5TY2T-TE39FQ-HC1YJ1
PS-00YWAH-M5TY2T-0EQTEB-PZ2PCR
PS-00YWAH-M5TY2R-EDR2HF-A69DYV
PS-00YWAH-M5TY2P-A8WC8F-2MJFJ0
PS-00YWAH-M5TY2Q-RYNDXT-CB94J4
I tried the code in bold letters above and it worked for me. Thank you for visiting FixYa!
May 26, 2011 | Computers & Internet
Driver for PS/2 compatible mouse for tower PC HP compaq dx7300 were not found and not installed in my PC.
PS/2 compatible mouse drivers are generic drivers already install when the Operating System to your PC. You don't need any extra PS/2 drivers!! "
Check your mousePS/2 pins & PS/2 socket -> Pins..Dented..Broken?
Mouse could be faulty. Try replacing another PS/2 mouse to your PC.
If the PS/2 socket is faulty, you can use a USB mouse too.
Hope it helps.
"Courtesy is free but it will carry you forward a long way in a lifetime!"
Nov 07, 2010 | Computers & Internet
Vista pc will not print to ir3220 via PS driver
What version of Vista driver do you have? PS 4.64 is the latest that I can locate.
Aug 07, 2009 | Canon Office Equipment & Supplies
Reset paa\ssword
Try this, it worked for my DP-300U.
username: psadmin
password: SYSXXXX (Where XXXX is the last four digits of the MAC address, which can seen on the underside of the server)
I learned this from viaujoc- (http://www.fixya.com/support/t224263-dp301p_psadmin_password_forgoten). On that post he also suggests a way of extracting the forgotten password from a configuation backup file.
Jul 01, 2009 | D-Link DP-300U (DHDP300U) Print Server
Pls help in this VB code, Sato CX400 barcode printer
jst try this u create a label from label printing software using ato font then make a prn
then attach u r vb code in to prn it will work
rohitjain
prn example-------------
A
Z
A
CB+18
Z
A
CD250,3300
Z
A
AR
Z
A
A100950647
Z
A
%2h416v0072BG01031>H23456111
%2PSP02h573v0021L0101XS922
%2PSP02h618v0021L0101XS18K
%2PSP02h415v0089L0101XS17125
%2PSP02h416v0039L0101XSPO124
%2PSP02h416v0022L0101XS215gms
%2PSP02h618v0043L0101XSDR37/0.20
%2PSP02h618v0064L0101XSDR37/0.20
%2PSP02h618v0085L0101XSDT/B44/0.82
Z
vb code example------------------
Open "LPT1" For Output As 1
Do While rs.EOF = False
For I = 1 To Val(Text1.Text)
Print #1, "A"
Print #1, "*&"
Print #1, "Z"
Print #1, "A"
Print #1, "CB+18"
Print #1, "Z"
Print #1, "A"
Print #1, "CD250,3300"
Print #1, "Z"
Print #1, "A"
Print #1, "AR"
Print #1, "Z"
Print #1, "A"
Print #1, "A100950647"
Print #1, "Z"
Print #1, "A"
X = "%2h380v0065BG01031>H"
Y = rs.Fields(6).Value
X = X + Y
Print #1, X
Print #1, "%2PSP02h618v0085L0101XSKT"
Print #1, "%2PSP02h600v0085L0101XS", rs.Fields(1).Value
Print #1, "%2PSP02h618v0064L0101XSNetWt"
Print #1, "%2PSP02h600v0063L0101XS", rs.Fields(2).Value
Print #1, "%2PSP02h618v0043L0101XSDiaWt"
Print #1, "%2PSP02h600v0041L0101XS", rs.Fields(3).Value
Print #1, "%2PSP02h618v0021L0101XSColWt"
Print #1, "%2PSP02h602v0021L0101XS", IIf(IsNull(rs.Fields(4).Value), " ", rs.Fields(4).Value)
Print #1, "%2PSP02h430v0084L0101XS", rs.Fields(5).Value
Print #1, "%2PSP02h371v0028L0101XS$"
Print #1, "%2PSP02h405v0028L0101XS", rs.Fields(7).Value
Print #1, "&"
Print #1, "Z"
Print #1, " A"
Print #1, " #E5"
Print #1, " Z"
Print #1, " A"
Print #1, " CS2"
Print #1, " Z"
Print #1, "A"
Print #1, " 0000"
Print #1, "TEXT1.TEXT"
Print #1, "/"
Print #1, "Z"
Feb 04, 2009 | SATO CX400 Thermal Label Printer
Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
Faulty ps/2 connections
Without know what computer you have, you should be able to go into setup (BIOS) and set the mouse to "none".  It should start.
Oct 25, 2007 | Microsoft Multimedia Internet Keyboard...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
