Question about Xerox WorkCentre 7228 7235 7245 7328 7335 7345 Fuser Cartridge 008R13028
Xerox workcenter 7245 error code 062-380 - Xerox WorkCentre 7228 7235 7245 7328 7335 7345 Fuser Cartridge 008R13028
  • 2072 Answers
SOURCE: xerox workcenter pro 765 error 22
That is a fuser not reachine tremperature fault.
Most likely the fuser will need replaced.
Go to google and type in "the parts drop".
Call Britt and he should be able to fix you up with that part for a fair price.Just tell him the model number and code.
Posted on Aug 18, 2008
  • 2072 Answers
SOURCE: I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Posted on Jan 25, 2009
  • 2072 Answers
SOURCE: Cant locate the printhead on xerox C2424
Remove the covers. But before you go to eh print head itself, there is a print head pivot block that often gets contaminated with ink. The code you are having, is related to the print head not being able to move freely side to side, or tilt properly.
To access that block. You have ot remove the document feeder and scanner. To do that you disconnect the cable, it runs from the back to the scanner to the opening where the power cord plugs in, remove the 2 thumb screws and unplug it. You slide the doc feeder and scanner back, then depress the two tabs and completely remove it.
There is one screw in the back that holds on both the left and right side covers. You have to lift and kind of twist the covers in about the middle of the machine, The front cover will also pop off, it has tabs that holds the front covers together. Then remove them.
Look on the left side of the machine, looking from the front. You will see a stainless steel block, about one inch square, located about 2/3rd of the way back on the lower 1/4th of the frame. It has a spring and a clip over it. Just pull out on the spring bracket and locate it up and to the left, It is meant to be put there for servicing.
Look at the block. it may be filled up with yellow ink. If so , remove it with channel locking pliers. It may be VERY tight, so work it out slowly. Then soak it in hot water, that softens the ink , and clean it and the shaft thouroghly and remove as much excess ink from teh surrounding area as possible. Also, IF that is the problem. Probably a 75 percent chance, then when you return the printer to service. Get a small level, and make sure the printer is level BOTH side to side and front to back. To do that , you place the lecel on the platen glass, sideways then front to back. Often times those printers are not level and that causes the problem. The other things that happens is simple spill over from the ink catch tray, It is imperative you have those printers sitting level.
If thats not the problem. let me know We will go from here.
Posted on May 18, 2009
SOURCE: Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Posted on Sep 17, 2009
  • 24 Answers
SOURCE: xerox workcenter 7665 communication problem
This was an issue with earlier models and is usually attributed to the "USB" connector on the bottom of the control panel not being attched securely. Note: although the connector is USB, it is NOT hot swappable and will crash the machine if unplugged while the power is on.
Power off the machine. Ensure the cable is securely attached and restart the 7665. Make sure when you turn it off that it is completely off before restarting or you could corrupt the system software.
Posted on Oct 25, 2009
Erreur cod 009-330 xerox 7245
009-330 error code xerox work center 7345 problom & soluson
Jul 10, 2014 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Fault error occurred no. 123-333
I install xerox new machine when turn on gives error code 123-333
Jun 20, 2013 | Xerox WorkCentre 7228 7235 7245 7328 7335...
Xerox workcentre 7245 error codes 004-361
Drum motor failure.
If you have a new drum, try replacing the drums 1 by 1 and see when the error clears.
Also make sure the guide rails are in the correct position
Mar 16, 2013 | Xerox DocuColor 3535 Copier
Xerox DC250 error code 116 340
my machine is the xerox 7245
erros is the 116-340
Nov 03, 2012 | Xerox DocuPrint 340A Laser Printer
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox WorkCentre 7228 7235 7245 7328 7335 7345 Fuser Cartridge 008R13028 Logo
330 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
