Question about Targus Numeric Keypads AKP10US Numeric Keypad - keypad
Targus num lock on off - Targus Numeric Keypads AKP10US Numeric Keypad - keypad
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
My keyboard is typing numbers and characters instead of letters!
Sounds like you have num lock on. The Num lock key is usually the same as Scrlk but to select the Num lock you have to press and hold Shift then press NumLk/ScrLk. A light should light up to indicate the keypad is on/off.
Regards,
G33k
May 11, 2011 | IBM ThinkPad T30 2366 Notebook
My Tarsus Keypad works fine on my on local laptop(Lenovo Thinkpad, Windows 7) However, when I use VPN and Remote Desktop to get to my desktop computer at work(Windows XP) the keypad only does the lower...
Not to be smart, but the same thing was happening to me and I realized the Num Lock needs to be activated on the keypad AND on your laptop. I did not have it activated on my laptop and I was realizing the same problems.
Mar 18, 2011 | Targus USB Ultra Mini Keypad Keyboard...
Push Num Loc get 5, push BS get 6, push 6 get \, push 4 get g ?????
semd to be an error keyboard mapping, select your correct language
Mar 03, 2011 | Targus USB Ultra Mini Keypad Keyboard...
Whenever I hit a number key it turns on and off the num lock (when num lock i off on keyboard). I use the keypad to play games and this just minimizes the game and shows me a messgae about num lock be...
This keypad is meant for mass number data, not as a joystick replacement I'm afraid.
Did you install any software that came with it? If so, try removing it Normally you don't have on-screen NumLock messages, so this must be something extra.
It clearly wants to be used for number entry. Perhaps it has some switch to change it's behavior, either physical, or in software?
Mar 12, 2010 | Targus USB Ultra Mini Keypad Keyboard...
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
Old keyboard still connected note worthy keyboard
when you start computer just press del and go to cmos bios setup and set usb keyboard setup enabled and save the setting.
Sep 08, 2009 | Targus Noteworthy Multimedia Keyboard...
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
Targus Numeric Keypads AKP10US Numeric Keypad - keypad Logo
Top Targus Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Targus Audio Player and Recorder Expert? Answer questions, earn points and help others
