Question about Seiko Smart 440 Thermal Label Printer
Troubleshooting won't open and print saved labels
Print dosent stop
u have to create your label at printer properties.
if prints doesn't fix your label, this problem appears.
( for 80x40 cm barcode: open printer properties-printing defaults - label size - new custom size or new label - write your sizes at size fileds- and save)
open your app, and create new file, type your sizes for new file, and print it!
Jun 25, 2013 | Zebra Eltron TLP 2844 Thermal Label...
Hotpoint water heater the electric igniter won't spark
Copy following link for troubleshooting igniter, and troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#igniter
Add a comment and say what manufacturer appears on label.
Open link above and scroll to top for information about FV lockout.
Mar 16, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
How to download programe to print labels
Easy Label Printer is a simple program for printing addresses on to sheets of labels, and the only one, as far as I know, to print addresses directly from the Windows Address Book (XP) or Windows Contacts (Vista).
Here is the link
http://www.tucows.com/preview/370301
At that page, Simply click on the "DOWNLOAD NOW" button, and when asked to save or open, SELECT & Click on "OPEN"
After the download finishes it will ask you to confirm opening, so click OPEN.
The Label program will begin installing.
After installing find the program in your programs listing menu and start it up.
If you need help with the program itself click on the menu item "HELP".
I hope this helps, if it does please consider giving me a good rating as this is the first "HELP" that I have answered here :-)
& Good Luck!
Sep 17, 2011 | Microsoft Computers & Internet
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
Aug 13, 2011 | Zebra 105SL Thermal Label Printer
Hi. We are trying to use an avery label 22807 and also 22806 for a label factory logo we created. We need measurements/diameters so that we can print on these labels. They keep printing wrong. ...
If you are using Microsoft work to print the label, then follow the link below to Avery's website. The link is to their find a template, type in the label number in the Product # or Keyword search box and it will take you to a down load for that label. Click on the download, you will be asked for some information before the download begins. Follow the instructions on the next page (save the file and remember were you saved it). When you open the saved file it will be in Word and you can go from there.
http://www.avery.com/avery/en_us/Templates-%26-Software/Templates
I hope this helps you out.
Jul 22, 2011 | Computers & Internet
HAVE A FLASHING ERROR LIGHT. CHECK RIBBON. RIBBON IS NOT USED ON THIS PRINTER. HOW DO I CLEAR THIS UP?
Changing the setting on the printer The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
Jul 09, 2011 | Zebra 105SL Thermal Label Printer
I've got some problems with my zebra zm400 printer. It says error ribbin out
May 05, 2011 | Zebra 203DPI Printer
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
Hi
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Daniel
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Zebra printer is eating labels on and off. I feel when the printer runs out of labels it losses the labels and never prints it again when the Labels are reloaded. Is there a configuration setup for the...
is possible calibration issues. please run manual calibration,
go through the setings and run MEDIA and RIBBON CALIBRATION.
if ask to load labels,
open printhead, take 2-4 labels from the back papel and load the back paper normaly.
then press enter. Ask for REMOVE RIBBON? open printhead and move the ribbon from left to the rigth of the printhead (remove from the sensors(left and side)) press enter.
let the printer save that figers from the sensors (back paper/no ribbon)
LOAD MEDIA?
ok, put all back on normaly (labels and ribbon set up proply) press enter.
The printer going to run the calibration, if stop on the gap?! save (press twice on SETUP Button.
SAVED? OK. turn of and turn on again, send the job.
Hope help. Rate please. Thanks.
Dec 17, 2010 | Zebra Z4Mplus Label Printer
Seiko Smart 440 Thermal Label Printer Logo
26 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Scott Kalvinek
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
