Question about Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor
Start capacitor breaker - Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor
Have a 21 gal central pneumatic. 2.5 hp. With no pressure in tank, plugged into wall outlet. Upon start up it will run 20 seconds then the breaker on motor case trips. Barely used this thing.
the thermal circuit breaker is overloading
that can be from a faulty tcb or a problem in the compressor ( seized)
most need start/run capacitors for the motor to start and if it / they are faulty then that will blow the TCB
if it has 2 capacitors ( one for start which it is doing and the other for run then that capacitor may be the problem
if it has the one unit with 4 wires , replace the capacitor
suggest that get an electrician in to check out the unit
Sep 18, 2016 | Air Tools & Compressors
Compressor starts innitially,then when pressure gets low it trips breaker when it tries to start back up.20 amp breaker to light switch to compressor is about 2o ft on12-2 wire. tried 30 amp breaker,does...
the start capacitor on the motor body is weak,the motor needs this component to over come the air pressure when cycling to re-build the low air pressure,change both the start and run capacitors when doing the start because the other run capacitor is just as old and it will soon fail
Mar 19, 2011 | Craftsman 33 gal Air Compressor 6 hp...
Compressor is blowing breaker, fan comes on. Ac worked fine last season. when trying to go to any cool setting, compressor will actually stall generator, or trip breaker if attached to house
You have a faulty start capacitor. The capicitor helps start the motor ... since it is not doing its job, the motor draws LOTS more power from the line popping the breaker. Have your professional RV service center service your AC.
Thanks for your interest in FixYa.com. Please remember to evaluate this response.
Jul 05, 2010 | Dometic Rooftop RV Air Conditioner
Popping circuit breaker
If you're popping a breaker, you either have a weak breaker or you have a short in your unit. If it's the outdoor unit that's tripping your might check the amps when the unit is trying to start to see what the amp draw is, then check the fan motor, fan capacitor, compressor, compressor capacitor, start capacitor and start relay or points on contactor. If you're not fimiliar with electrical it's best to have a HVAC company check this for you.
Jun 03, 2010 | Heating & Cooling
Heat pump kicks breaker outside in main breaker panel
the start capacitor is bad. Motors develop what is known as lock rotor amperage. requires alot of torque to turn the motor until it reaches iits rated or run load amperage. the motor is not able to overcome the lock rotor amps which is usually 5x the rated amperage and always more amps than the breaker. this is usually not a problem because the start capacitor helps overcome the LRA so quickly that it doesnt trip the breaker. If the capacitor is round and bad it will be bulged at the top, if it is oval shaped then the rupture disc on top will be blown letting all the dielectric fluid out which cools the capacitor
Dec 10, 2009 | Haier Energy Star ESA3183 Air Conditioner
Trips breaker, windings not open, no continuity from windings to frame. startsfor split second then trips breaker. Breaker is ok
ASSUMING THIS IS SINGLE PHASE HAVE YOU CHECKED THE CAPACITORS. START CAPACITOR COULD BE BAD OR BURNT LEAD. HAVE YOU MADE SURE THE PUMP IS NOT LOCKING UP. POINTS IN THE PRESSURE SWITCH LOOK GOOD. HOPE THIS HELPS, JODY
Apr 26, 2009 | Plumbing
Air cond works for 10-15 min. then pops circuit breaker.
Start capacitor, fan motor or the compressor is worn out. Most times its start capacitor. Thanks, Sea Breeze
Mar 24, 2009 | Dometic Rooftop RV Air Conditioner
Only fans work on split system model ls-k2463hl earth breaker trips when compresor tries to start I own a Panasonic Heat pump model A18CKP6G with the same problem. The compressor was replaced last June...
Sounds like a wiring problem between the outdoor unit and the house. You would be surprised what I have come across in 30+ years of A/C work.
But it could also be the compressor.
I will need to know answers to the following -
Does the compressor have a soft start (2 wire capacitor looking device that attaches to the run capacitor), hard start (relay and capacitor), or just the run capacitor?
Were the run capacitors and start components replaced when the compressor was replaced?
Is the breaker a GFI breaker, or just a standard breaker?
Rain or humidity is not usually a factor, but it may be something.
Reply back what you find.
Feb 01, 2009 | Heating & Cooling
Starting problems
IF YOUR PRETTY SURE DRAW A CAPACITOR WIRING DIAGRAM AND THEN TAKE YOUR CAPACITORS TO ANY MOTOR SHOP OR SUPPLY HOUSE LIKE WW GRAINGER. THEY CAN CHECK THE MICROFARRADS OR UNIFARRADS OF YOUR CAPACITORS. YOUR START CAPACITORS HAVE THE LARGER MF OR UF RATING AND ARE TYPICALLY LARGER IN SIZE. YOUR P.O.S. INGERSOL RAND MAY EVEN BE A 3500 RPM MOTOR AND COULD HAVE UP TO 5 CAPACITORS. 3 OF WHICH ARE START. IS YOUR WIRE LARGE ENOUGH? IS YOUR BREAKER LARGE ENOUGH? IS YOUR COMPRESSOR UNLOADING THE HEAD PRESSURE WHEN IT CUTS OFF? IS IT OUTSIDE AND TOO COLD IN THE MORNINGS? MAKE SURE YOUR WIRING IS LARGE ENOUGH BECAUSE THAT IS USUALLY THE PROBLEM. YOU HAVE SINGLE PHASE BUT IS YOUR VOLTAGE CORRECT 208V OR 230 V. ALL WIRING AND GAUGING CHARTS ARE BASED ON 100 FT OF WIRE . MOST COMPRESSORS PULL 3 TIMES THE AMP RATING ON INITIAL STARTUP THEN COM DOWN TO AMPS LISTED ON THE MOTOR.
Jan 16, 2009 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand DD2T2 T Win Stack Single Stage Compressor Logo
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
