Question about Broan-NuTone Kitchen Ranges
Cold air blowing in what is wrong Nutone stove fan
Ice maker
  • 8 Answers
SOURCE: ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Posted on Mar 27, 2008
  • 4 Answers
SOURCE: Heater on driver-side blows barely warm air other vents blow cold
the most probabale cause of this would be a disfunctional hear core if you replace your heater your heater will more than likley work the the way it's supposed to
Posted on Jan 18, 2009
barkencoa
  • 3463 Answers
SOURCE: Oven blowing out cold air
You need to replace the oven element This is located at thr rear of the oven compartment.
If there are no screws securing cover at rear of oven compartment, then you are going to have access it from the rear of the oven cabinet, on the outside.
Hope this helps.
Posted on Dec 20, 2009
  • 93 Answers
SOURCE: heater will not blow hot air. it blows cold air
The heater core is possibly blocked or the temperature adjuster is not working.
First check the controls to be certain that the temperature aduster is working and the flaps/doors that direct the flow of hot air are working.
If they are..........
Check heater hose temp. If one is hot and one is cold, you are not getting flow through the heater core.
Bleed it to remove an air blockage.
If that does not work, flush the system.
If that does not work, replace the heater core.
Karl at topgunwon.com
Posted on Feb 18, 2010
SOURCE: air conditioning is blowing out hot and cold air
It sounds like the dual climate control valve. It is supposed to close the valves when the a/c is turned on, but they get stuck sometimes. I have already replaced 2.
What happens is the valves get stuck and the engine heat will blow over the cool air making it feel warm, even though the a/c is working fine.
If it started out on one side of the car cooling better than the other than you can almost bet this is the problem.
They will be called a heater control valve by most auto parts stores. I think the part is Motorcraft YG378.
Another way to make sure this is the problem is to find the dccv and clamp the two top black hoses with pliers or something and see if the car gets cooler. It will still not get cold but this will let you know if the dccv is the problem.
Posted on Jun 09, 2010
My quadrafire 1000 pellet stove works great, but the 2nd fan will not shut off and continues to blow cold air. Any suggestions
when turned off the fans continue to run to cool down and exhaust fumes --turns off when firebox reaches a set temperature
Oct 27, 2016 | Heating & Cooling
Fan oven blowing cold
The fan inside an oven is usually for convection cooking. It circulates air that is already heated. It is not a heater.
Apr 29, 2014 | Candy Ovens
Old NuTone 9093n Model replacement.?
Hi -- I just spent a couple of days taking out the old assembly, cleaning all the parts (layers of dust coats) and putting the 9093N back in order to fix the noisy fan. The cold air coming back in is from to the heating and I'd guess the heating element is busted. Yes, you can run it in both airflow modes: ceiling air exhaust and hot air blown to the floor. That said, the noise level on mine hasn't gone down. So I'll look for the replacement assembly. Good luck!
Mar 23, 2013 | Broan-NuTone Dryers
Heater blowing out cold air
Several things.
If the heater hoses are hot, the problem could be a blend door under the dash. The blend doors direct air thru the heater core and out the vents.
Jan 24, 2013 | 2005 Dodge Caravan
Just installed the hood range and it is blowing not sucking
The blower is either installed wrong or the motor is running the wrong way...
heatman101
Feb 08, 2011 | Broan-NuTone Kitchen Ranges
My Bathroom Fan (Nutone) is sucking very little but blowing quite abit from around the fan asembly meets the cutout in the ceiling. The vent outside is blowing out quite a bit of air, (more than whats...
if there is no suction my question back you would be do you have a leak around the box in the cealing did you use calking material when you installed it? let me know so I can help. Also do you have a window open to see if the room breaths? Just some ideals Reply back for more help.
Aug 31, 2010 | Broan-NuTone N-763RLN Combination Light...
NuTone bathroom fan starts slowly after being off awhile
need to blow it out with a air hose and oil it real good! but keep a eye on it to make sure it does not get hot! if it feels hot to touch replace the motor!
Nov 03, 2009 | Broan-NuTone (668RP) Fan
Air conditioner is not blowing cold air. Any idea
could be anything from low refrigerant to bad compressor cooling fan or air distribution system. if you never have worked on a c i would recommend taking it to a professional
Jun 26, 2009 | 2005 Dodge Grand Caravan
Heater doesn't work
You can purchase heating elements for this fan that will solve the problem. This is a fairly new fan model so I would recommend calling Nutone because this model has a three year warranty. They may send you the part you need for free.
Jan 28, 2009 | Broan-NuTone QTXN110HL Fan
Kitchen Ranges Logo
23 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
