Question about Revolabs 07-TTDIAL-01 - Fusion Tabletop Dialer
No connection to base - Revolabs 07-TTDIAL-01 - Fusion Tabletop Dialer
BT8500 "No link to base, please check base." How can I when I can't access base. Base replaced but fault still exists. Can anybody help?
if you have a cordless phone and you changed the base with out noticing if it is compatible with the hand piece then it will not connect
read the user manual for the base registering hand pieces for connection
Dec 13, 2016 | Lands Phones
Connected ground wire to base. A hole is provided. Should I connect that ground green wire to neutral which is is in the middle or ground green to base, which I did.
IF UR TALKING BOUT A 3 PRONG THEN IT GOES TO THE BASE UNLESS U HAVE A COPPER JUMPER WHICH CONNECT TO THE MIDDLE AND THE BASE
Sep 04, 2014 | Hotpoint Dryers
DO GRACO SNUGRIDE INFANT CAR SEAT BASES WORK WITH A DIFFERENT MODEL?
Some do, some don't.
From Graco's web site:
What base will work with my car seat?
We have designed many of our car seats to work with more than one base, for your convenience. Please see the chart here for Classic Connect models.
The SnugRide Click Connect 30, 35, 35LX and 40 infant car seat carriers are compatible with any SnugRide Click Connect infant car seat base. Consumers should adhere to the height and weight requirements for the SnugRide Click Connect infant car seat carriers as stated in their owner's manual; however, the SnugRide Click Connect 40 infant car seat carrier is restricted to a height limit of 32 inches when used with a SnugRide Click Connect 30, 35 or 35LX base.
Jun 15, 2014 | Graco Baby Gear
Bought a spare 3111 handset and cant connect it to my base. it looks as if it was connected to another base at one time. screen just says "connecting..." and there is nothing I can do to clear...
The handset must be registered to the base unit if the system has multiple handset ability, the manual will tell how to register the handset. If the system is a two handset system then only two handsets can be registered.
Dec 08, 2010 | Vtech Cordless 6041 Phone
Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Mar 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
No link t move closer to base try again base
this depends on what phone you have. most pjones when you open the back of the battery cover, their is a connect button really small. look around the base for a connect button and press the base connect button first, then the phone. after abit they should connect to each other. plaese let me know if this does not work
Feb 23, 2010 | Lands Phones
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
3CRWER100-75 no DHCP IP on child routers
router 1 (base) router 2 (repeater) router 1 (base) is the network, the SSID is where u get your internet connection set router 2 with same SSID, DHCP on. i advise connecting hardline to make sure both routers are working correctly. once thats verified then go wifi
Jun 30, 2008 | 3Com OfficeConnect Wireless 11g Cable/DSL...
No Link To Base Unit
I am having the same problem!
Mar 10, 2008 | Panasonic KX TC1743B Cordless Phone
Phones won't pick up calls...say connecting
HOLD THE HANG UP BUTTON AND THE POUND BUTTON DOWN FOR 5 secons. select base unavailable....yes. then hang it up on the base and it will register to the base. if that doesn't work then unplug the base then plug it back in then put the reciever on the base.
Nov 20, 2007 | Uniden TRU9380-2 Twin Phone
Revolabs 07-TTDIAL-01 - Fusion Tabletop Dialer Logo
Top Revolabs Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Revolabs Lands Phone Expert? Answer questions, earn points and help others
