Question about Cameras
Arm on Elmo TT-02S won't stay up - Cameras
2 Suggested Answers
  • 3 Answers
SOURCE: Teacher Tools Elmo TT-02S
check the 2 little switches on the back it is possible that they are in the wrong position. for a pc or video projector the switches have to be in RGB.Check those switches and turn it back on .That is most likely your problem
Posted on Oct 10, 2010
I need the diagram of a elmo for repairs
I found a manual for this classroom projector at projectorcentral.com in their .pdf library. Good Luck !!!! Jim
Sep 27, 2012 | Elmo Projectors Tt-02s Slide Projector
InFocus IN2102EP Projector My projector is connected to an Elmo TT-02s digital presenter that I use to show documents to my Students. When I first power on both devices, they seem to be working fine then...
Most projectors have an auto search function which can be switched off. You can then set the source to the specific input that you are using. Of the problem persists it may be the battery of the Elmo. (If it has one) Maybe it isn't strong enough to send the signal and maintain it.
Good luck.
Aug 05, 2011 | InFocus IN2102EP Projector
My Elmo TT-02RX document camera is not working properly. The blue power light does not stop flashing when I turn it on, and I am unable to use the camera or switch over to projecting what is on my...
Your Elmo TT-02rx comes with a five year manufacturers warranty. Contact Elmo at 1-800-947-ELMO and they will instruct you as to how to trouble shoot your doc camera or send it in for warranty service.
Apr 14, 2011 | Elmo Projectors ELMO TT02RX DIGITAL...
Zoom dial is broken teacher overturned it
don't have a solution but I have two Elmos tt-02s with the same problem
Feb 11, 2011 | Elmo Projectors Tt-02s Slide Projector
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
No live image
there is a setting on there for camera. if you're going through video, s-video, or computer, make sure the output is correctly selected. if still no video, you may have to send it in for repair. try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 07, 2009 | Elmo Projectors Tt-02s Slide Projector
Dec 20, 2008 | Elmo Projectors TT-02U Camcorder
Elmo TT-02u, Random freezes
The problem is a set bad capacitor that must be replaced by the factory. The units are very critical on the exact amperage that the power supply delivers. We have hundreds of tto2 and a few have had this problem. Elmo is aware of the problem and your warranty should cover the problem.
Oct 09, 2008 | Elmo Projectors TT-02U Camcorder
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
