Question about Sony VO-9800 VCR
How Does One Adjust Settings for Reading Time Code?
Our dubhouse SAYS they sent us U-Matic dubs with SMPTE time code. The time code is not displaying on the internal reader. When I plug in a time code reader to the TIMECODE OUT port, I get nothing. Unfortunately, we've misplaced our manual for our VO-9800 so I can't refer to it. I would appreciate any help.
You have to use the "dial menu operation"! where the buttons "menu" "data" and "set"
Posted on Oct 13, 2007
Hola,saludos,por fabor,necesito saber? Como hacer para poder,activar un Dvd en una pantalla super matic,con el control super matic,el Dvd es de otra marca,sanyo,gracias,Xinia
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. ..
Dec 04, 2016 | Televison & Video
What does error code e22 mean
e22--will not finalize DVD-R disk (due to dirty lens, I think)
*unplug unit and replug after 20 minutes
*restore settings if needed, and reset clock
*insert & run/play a DVD lens cleaner disk
*dub video from the HD to a NEW BLANK DVD
*finalize after dubbing is finished
THIS WORKED ON MY MAGNAVOX MDR 533H/F7
PS: make sure that the new blank DVD disk is from the same pile of disks that you were able to finalize before.
Feb 08, 2016 | Magnavox ZV427MG9 DVD Recorder/ VCR
Download Digitech Weather station XC0346 Manual
To set station Hold SET key down for 3 secs. Press SET key to select setting in this sequence. 1. Time Zone 2. 12/24hr format 3.Manual time setting HR/Min. 4. Calendar setting y/mm/dd 5.Temp display C or F 6.Air pressure display hPa or inHg 7.Relative pressure setting from 919.0hPa-1080.0hPa 8 Pressure threshold (sensitivity)Default 2 9.Storm threshold Default 4 10.Wind speed reading km/h, mph etc 11 Rainfall display in mm or inch. Use the + and History keys to adjust values (History key is - ) When replacing batteries Fit outside unit ones first then fit inside unit ones in that sequence so it can interpret the security code.
Apr 05, 2012 | Measuring Tools & Sensors
Screen too narrow. Difficulty in reading. First time this has happened
go on control panel adjust , display settings on personalize settings,
Mar 23, 2012 | Computers & Internet
Resendly purshased a casio 4772 watch. diplay time and city. trying to get it set for dst. read manual and cant get button (A) to flash. can u help
Hi ...
your watch supports Time Zones , Automatic time Updates, Automatic adjustments of DST.
First Verify Correct Home City Is Selected
1. In Time Keeping Mode (That is The Digital Display shows time and Day of week)
2. Press Button (A) long enough to country code start to flash on digital display.nightflare_4.png
3. Press Button (B) or Button (D) to change Country code to current one.
4. After Selecting Desired Country, Press button (A) TWICE.
Now Country Code will be saved on watch.
Supported Country codes are:-
To Activate DST (Daylight Saving Time).
2. Press Button (A) long enough to Digital Display start to flash.
3. Press Button (C) TWICE to Display DST Settings.
4. Press Button (D) repeatly to cycle through three DST Options:-
A --> DST is set on Automatic Mode. If Your country uses DST, the watch will Adjust DST Accordingly.
OFF --> DST is set to disabled. No DST is applied to Main Time Settings
ON --> DST is Set to On. DST is applied even if your country doesnot follow DST.
5. Press Button (A) TWICE to save Selected Option.
Default values (Factory Settings) when you bought this watch is
This way you can set DST
Mar 13, 2011 | Watches
Panasonic video projector, via Composite video in. Horizontal Dotted white line on top of picture edge Left hand side to nearly mid way point. What's going on?
You may need to adjust your overscan.
To do this you will need to press "MENU", choose "POSITION", now adjust the "V-POSITION" and move it only until the white line disappears.
The line that you see at the top sounds like SMPTE code, which is used by broadcasters for many purposes. http://en.wikipedia.org/wiki/SMPTE_time_code
Feb 24, 2011 | Panasonic PT-AE900U Multimedia Projector
Sumsung omnia sgh-i900 'AUTHENTICATION CODE'
If you asked for the settings to be sent from your providers web site they usually require an "Authentication Code" it should tell you what it is in the instructions on the website.
Try and send them again but remember the code :)
If your settings were sent after you called customer services then again you will need to get in touch with them and ask for the code.
I think it changes all the time so guessing may NOT be a good idea.
All you have to do with "Settings" text messages is read them and then delete them. Make sure in your text settings you have "Push Messages" selected.
I hope this helps? :)
Jul 22, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Mar 31, 2008 | Sylvania SRD3900 DVD Player/VCR
Synchronize the DSR-45 as a 'slave' to an external unit with SMPTE Timecode
if i,m not miss understanding the problem is rec audio ng.if it,s, the posible cause are; 1;head dirty at the line of the tape causing data from head can,t write the tape optimal.for this problem you can clean the head carefull the head can easy broke., 2;if the picture having tracking posible the guide that bring the tape at the left doesn't fully at the track.for this problem at emergency you can try to push the left guide.
Sep 19, 2007 | Sony DSR-45 Mini DV VCR
Sony VO-9800 VCR Logo
120 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
