Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Whirlpool washer I turn the power on, select cycle and press start and nothing happens. I hear clicking sounds, like it wants to, but it doesnt fill or spin
    Scholar:
  • 64 Answers
First you need to unplug the washer and then remove the front cover below the loading door... (Should be 3 Phillips screws on the very bottom). You will want to run the diagnostic program that is found in the manual which is also located behind that front bottom cover…if you can get it to run that program….. I also had to replace the CCU (Central Control Unit) and the Filter….due to the fact that I was getting a F11 & a F14 error… If you are hearing a faint clicking sound coming from the top back (before you get the F11 or F14 error or no error coed at all) then I know for sure you need to replace the CCU and Filter... At least that’s what I had to do…I will give you the link to the site where you can buy it....If you have any type of home protection plan I would just call them and pay the service fee (mine is only $50)....its going to be a lot cheaper that way…. If you decide to buy the part or parts…the CCU and the Filter control unit and do it yourself make sure you get the model number off the CCU and Filter control unit. The top cover is just as easy to take off...the CCU will be located in the center on top and the Filter just to its right... Please make sure the washer is unplugged before you remove any covers….I hope this helps....please give me a rating either way...here is that link to the website for those parts….it also gives you a good picture of the parts...Good Luck
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059617&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=939639&PPStack=1
cbinny1
Posted on Oct 20, 2008
  • 447 Answers
Make sure the water is turned on
Posted on Sep 27, 2007
Whirlpool Cabria: Power is getting to machine, but when you hit start button...nothing happens.
Sounds like something is jammed and overloading the machine. Check for locked motor.
Dec 21, 2017 | Whirlpool Washing Machines
How do I start a Whirlpool duet HT washer?
plug it in, press power button (blue button on left) turn dial to desired cycle then press and hold the blue button on the right until u hear a click then relese. if it doesnt light up the display when u press power the washer is broken.
Mar 11, 2013 | Washing Machines
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Whirlpool High Capacity washer, start cycle , it fills with water then no agitation, and no spinning.
next time send the model number,open the lid,look on the right side and there should be a hole in the top,that's the lid switch,it's used so the washer won't run if the lid is open for safety reasons,set it to spin and with a screw driver push down on the plastic piece in the hole,if nothing happens push in and release,do this a few times,if you don't hear a clicking sound when you push up and down the switch is bad or close the lid and open it an inch,close it and open it a few times,no clicking sound the switch is bad.
Jun 12, 2011 | Whirlpool 3.2 cu. ft. Washer
RCA Whirlpool Model LSQ9665J will fill with water but does not agitate, spin, or drain on any cycle. Was working fine yesterday.
put the timer on spin,open the lid,with a screw driver push down on the lid switch,if the washer starts to spin and drain the lid switch is bad,also if nothing happens,lift up and push down on the switch if you don't hear a clicking sound the switch is bad,all it is is a safety so the washer won't run with the lid open.part number 3949247 and the lid switch is around 40 dollars,
Apr 02, 2011 | Whirlpool Washing Machines
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer not cycling
I manually turned the impeller on the motor and "broke it loose". I found out if you don't use the washer for even a small period of time the motor may do this.
Jul 25, 2008 | GE 24 in. GSD2220Z Built-in Dishwasher
Washer fills up but won't agitate
get your screw driver and lets start.. first unplug the machine from the outlet, you have to access the water level sitch so remove the tab and there is the bandidt, knock him with the screw driver and if this not funcion replace it..good luck I dont tell you to check the thin hose in the water level sitch becouse you said its fill all right.
Aug 06, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
