Fisher dac-9025 digital compact disc changer-semi automatic turntable.wont revolve e-1 error message.
fingers2007
  • 6 Answers
SOURCE: Fisher-Price Digital Arts and Crafts Studio
Hi all frustrated fokes out there who still have problems installing and running this new product.
We bought this too for our dissabled daughter and have found it will not work on her pc , but will work on all the others in the house ..grrrrrrrrrr...lol.
What i did find was you must have net framework 1.1 installed and updated min for the software to install . other wise it will try to install the net framework 2.0 from the disk. the net framework 2.0 is an update from 1.1 and much software that requires net usage needs this base framework.
this is the spec of the pc it do work on ...and yer it well over the min requirement
System Information
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+, MMX, 3DNow (2 CPUs), ~2.4GHz
Memory: 2046MB RAM
Page File: 392MB used, 3547MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
The pc it will not work on only has 256mb memory,and a 128mb graphics card. Buy the time windows boots up and all the other programs also are running there is not enought memory spare to even launch the system. So a min of 512mb installed is required on a xp system
Another point i found was when i inserted the usb windows did not register it so following the install instruction very carefully ..eg start to installing the software and when it says to insert the usb cable do so then .
When you do get it working , your keyboard and mouse will not function, only ctrl+Alt+del will to interrupt the program . The pen will be your mouse thought i'd better say that cos it fooled me at first ..lol ..
Hope this helps ...
Posted on Dec 29, 2007
djproaudio
  • 515 Answers
SOURCE: I need a belt for a fisher DAC-145 turntable
You can find a replacement belt HERE.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
Posted on Jul 15, 2008
  • 16 Answers
SOURCE: Chevy Equinox 5 disc cd changer. Car battery died which cycled cd changer several times. Now it just gives cd error message and I cant get the lone cd out and I cannot load a cd.
make sure your alltanator is chargeing from the battery,how you can do that start the car open the hood and take one of the batter cable if the car still run,that means the alltanator is good,if the can turn off when you take the
Posted on May 11, 2009
SOURCE: 2001 honda accord cd disc changer wont work
2001 honda accord with three cds stuck inside. Wont play or eject just a whooring sound and error on display. Any ideas before going to the dealer?
Posted on Aug 06, 2009
  • 195 Answers
SOURCE: wont eject disc
Hi ziggyryshals,
You say that the record will not reject?
Have you pressed the cancel button on the back of the jukebox or on the mechanism (or carousel), it is on a plate near the tone arm.
If the button above does not reject the record turn the transfer motor by hand to manually reject the record.
I would check the trips on the power supply unit in the jukebox and make sure they are all pushed in.
If the fault still persists then contact a Rowe Ami repair man.
If you were in the UK then you could contact me for advice.
Regards
Alan Hood
ami-man
UK
alan-hood@datex.co.uk
Posted on Sep 07, 2009
I have 5 disc changer that will revolve but wont play disc just keep running.
What you hear running may be a fan, a motor that spins the CD, the motor that moves the head in & out, or the motor that turns the turntable.
I suspect on something that old, the motor that spins the CD may be worn out. Place 1 CD in position and make note of the exact position of the words on the CD, let the player go through all 5 positions and see if the CD is still in the exact position that it was when you started. If this is the problem there's usually no easy way to fix it.
If the turntable doesn't turn, then it's that motor or a possibly a belt that no longer works.
There is also the possibility that the read head is no longer moving in and out smoothly, you'll have to take the unit apart and re-grease the slides with light lithium grease.
The read head being dirty or too dusty is another possibility, but even less likely. When you get it apart, clean the read head with a cotton swab and rubbing alcohol, anything harsher might damage the components.
Oct 08, 2016 | Sony CDP-CE375 5-Disc CD Changer
I need a laser cd for a Fisher dac-145 turntable
I'm afraid I have no idea why you need a laser disc. For more information, please visit my website at audioserviceclinic.com. Thank you.
Oct 29, 2013 | Audio Players & Recorders
Technics compact disc player sl-hd501
Is there an error message? For more information, please visit my website at audioserviceclinic.com. Thank you.
Sep 19, 2013 | Audio Players & Recorders
I have a Fisher Compact 5 cd changer Model DAC 197 . Manufactured in 1988. Are the small rubber drive belts available , if not, are there any that are inter changable?
I had the same problem. I took the cover off and tried to eject a tray and saw that the small rubber band was slipping. I simply got a smaller rubber band and replaced it. It works perfect now. It takes longer to unscrew the case than it does to fix the problem.
Dec 28, 2010 | Audio Players & Recorders
I NEED BELTS PART NUMBER >!! FOR
here ya go these guys have it
http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=FISB02a
Mar 02, 2010 | Fisher RS920
CD Changer/turntable MDL Fisher DAC-145.
Hello....Give you local SEARS store a call and inquire...I've used them in the past...Their repair center does excellent work and repair more brands than anyone I know....If there are any up-front costs...they'll let you know...Try it and let me know....I hope this was helpful......PEACE.......
Feb 06, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Error message for Fisher Price digital arts & crafts studio
Simple fix. Go to the "Digatal Arts and Crafts"website http://www.fisher-price.com/fp.aspx?st=10&e=dacs-register. In "Software Updates" go to your version of the product and download and install the update.
Dec 29, 2008 | Toys
Error message
I had this happen to me as ell. you've probably got a cd stuck under the revolving tray. I took the top cover off and then opened the drawer and removed the offending disk. If you're not technically minded it's probably better to take it in to a repair shop. Mike
Dec 24, 2007 | Marantz CC-4300 5-Disc CD Changer
114 people viewed this question
 Grubhead
Grubhead
