Question about NEC VT460 Multimedia Projector
I am looking for a powercable (EU:7N080005) for a nec vt 46
Nec vt 595 lamp resat
press and hold help button for 10 sec..
May 09, 2014 | NEC VT595 LCD Projector
I AM LOOKING FOR SCREEN FOR TELEFUNKEN MODEL TLCD 46 FHD
you must search in the Internet for to supplier Telefunken. This company is coming from Germany. EU.
God bless you
Oct 11, 2013 | Audio Players & Recorders
GREEN GLOW on NEC VT 770 projector
That will be a worn or damaged green LCD unit. If still available, extremely expensive.
Jun 22, 2017 | NEC VT770 Multimedia Projector
I am receiving "Clean Unable 46" on my printer MFC-240C ....
Hi terri_robin
Click on the following link
Look for the title Error messages
Select LCD display on the printer
Look for Error 46
Looks like you need to replace the INk Absorption Pad.
Hope you have warranty still
http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/faq/faq_top.htm?reg=eu&c=eu_ot&lang=en&prod=mfc240c_all
Good luck
luciana44
Dec 01, 2009 | Brother MFC 240C All-In-One InkJet Printer
Filter on a nec vt 595
office.manualsonline.com/manuals/mfg/nec_display_solutions/nec_display_solutions_projector_product_list.html
here you will get manual it has complete details on the filter . please rate my answer
Jul 03, 2009 | NEC VT595 LCD Projector
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Looking for manual for ''nec n-3480'' TV, missing power cord
Colour code Standard wire colours for flexible cable
Such as Extension cords, power (line) cords and lamp cords World Region, country
or other entity(ies) Live Neutral Protective earth/ground EU, Australia & South Africa (IEC 60446) brown blue green & yellow Australia & New Zealand (AS/NZS 3000:2000 3.8.1) red black green/yellow United States and Canada black (brass) white (silver) green (green) Standard wire colours for fixed cable
(In or behind the wall wiring cables) Region Live Neutral Protective earth/ground EU (IEC 60446) including UK from 31 March 2004 brown blue green & yellow Australia and South Africa red black green & yellow (core is usually bare and should be sleeved at terminations) United States and Canada black, red, blue(brass) white (silver) green (green)
or bare copper wire Note: the colours in this table represent the most common and preferred standard colours for single phase wiring however others may be in use, especially in older installations.
Nov 19, 2008 | Televison & Video
NEC VT 460 LCD Panels & Fly Eye Lens
HI there
Firstly this ghosting image will NEVER be caused by your LCD's , so do not take them out.
Have you tried using a different cable ?
If you have and the problem still occurs , you will have to look at replacing the Mainboard.
Apr 13, 2008 | NEC VT460 Multimedia Projector
NEC VT460 Multimedia Projector Logo
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
