Question about Macromedia Flash MX
Flash File Overall Color and Contrast too light
I am having a flash file created from an Illustrator file I created. We have already used the same inages and colors and picked them to be their best for the screen and I understand the difference between Illustrator colors and the way they can look different once on the web. But we put the same files up on the web to view the colors (but just not a flash file) and when we view the flash file being created next to it it is definitely a significant difference in the overall contrast and color being lighter. The flash file is too bright. Is there some sort of loss that occurs within the files when going from Illustrator to flash? Is there a way to adjust the overall darkness/lightness or contrast of a flash file?
MAINLY CONTRAST OF THE FILE IS DUE 2 BRIGHT COLORS. SO YOU BETTEER 2 USE LIGHT CLORS. & BRIGHTNESS MUST BEE REDUCED 2 SOME WAT ACCORIND 2 YOUR PROJECT
Posted on Sep 28, 2007
How to retrieve lost data?
Copyartwork from a damaged repair illustrator file.
  1. Open the damaged file, and then choose Object > Path > Cleanup to remove unwanted items (for example, stray points, unpainted objects, empty text paths) from the artwork.
  2. If the original file contains multiple layers, choose Paste Remembers Layers from the Layers Panel pop-up menu to ensure the artwork appears on the same layers when you paste it into the new file.
  3. Using the Selection tool, drag a marquee around the artwork.
  4. Choose Edit > Copy.
  5. Choose File > New to create a new file.
  6. In the new file, choose Edit > Paste In Front to paste the artwork in the correct position on the page.
  7. Choose File > Save.
If the new file exhibits the same behavior, it may contain a damaged object. To determine whether an object is damaged, delete it from the new file, and then save and reopen the file and try to re-create the problem. Repeat for each object in the file.
When you can no longer re-create the problem, delete and re-create the damaged object in the original file:
  • If an Illustrator-drawn object is damaged, then re-create the object with the drawing tools in Illustrator.
  • If a linked image is damaged, then re-create the original image, and then replace it in your artwork.
  • If a text object is damaged, then convert the text object to outlines or change its font.
To quickly change all fonts in a document:
  1. Open the document in Illustrator and Choose Object > Unlock All.
  2. Choose Edit > Select All.
  3. Choose Type > Font, and select a font not currently used in the document.
Note: To prevent text objects from becoming damaged in the future, reinstall the problematic font from the original disk.
https://helpx.adobe.com/illustrator/kb/troubleshoot-damaged-illustrator-files.html
How To Repair ai file
Mar 10, 2018 | Adobe Computers & Internet
Tip
DVD to flash converter, convert DVD movie to Flash, embed DVD to website
DVD to Flash converter provides a fast and easy way to batch convert your DVD movies to Flash and separately convert any title or chapter of DVD video clips to Flash FLV/SWF on Windows, including Windows 7. After convert DVD to Flash, you can deliver your DVD movies to website with its export HTML web page embedded video. DVD to Flash converter also allows you to select your favorite DVD subtitle and audio tracks from DVD movies.
With DVD to Flash converter, you are able to make flash video, even without any programming knowledge, through making use of its powerful flash video editing features. For example: Clip video to get any segment from DVD movies(supports clip one file many times); Crop DVD video clips to get rid of the black sides; Apply effects to video like Gray, Old Film, Emboss; Make a video sliding to get a video playlist; Join several DVD titles or chapters into a single one; Change video Bright, saturation and contrast; Take video flipping vertically and horizontally, etc.
DVD to Flash converter offers an amazing feature, "Customize", which can help you to create more vivid flash video. For example: Set video frame rate, bit rate and profile(hd format, high quality, normal quality, low quality) to define the output quality as wish; Create a flash player, special effect for flash video; Add preloader template to flash video; Make a skinnable control bar to control SWF files with "Start", "Stop", "Pause "button, progress bar and volume controller; Add text or image to video as watermark; insert URL/hyperlink in video; Attach flash frame at the beginning and end of flash video. DVD to Flash converter is powerful yet simple to use program, with a few mouse clicks to finish DVD to Flash conversion.
Download Now
Key features: Convert/Rip DVD movies to Flash FLV SWF for website
Convert all DVD video to Flash FLV, SWF files, including commercial and home-made DVD movies
Automatically embed Flash video in an html webpage so as to add your video to website without actionscript
Export flash video in HD format, with high quality, normal quality or low quality
Support batch processing to convert multiple DVD video files
Versatile Editing Features to Edit Flash video easily
Crop video to remove the unwanted parts like black bars or black sides
Adjust video brightness, contrast, saturation and add effect(Gray, Old Film, Emboss)
Clip DVD videos to get multiple segments
Merge multiple video clips into 1
Slide DVD movies to create a video playlist
Powerful Customize Features to create Flash video
Take audio and video settings, such as set video frame rate, bit rate and flash video height and width
Provide four output profile: hd format, high quality, normal quality, low quality
Select a skinning flash player, special effect, preloader template for flash video and a favorite color as background
Create a control bar with many styles and"Start',"Stop',"Pause"button, progress bar, volume controller to control SWF files
Add text or image to video as watermark and embed an URL/hyperlink in video
Make a head and tail frame separately at the beginning and end of flash video
It is for windows user, if you are mac user, please use DVD to Flash video converter mac version
on Mar 15, 2010 | Computers & Internet
I very much like to work with graphic things
How to repair ai file?Place the damaged Illustrator file in a new Illustrator file.
Important: This solution doesn't work if you didn't select Create Compatible PDF File in the Illustrator Native Format Options dialog box when you saved the original file. On the Macintosh platform, the damaged Illustrator file may appear dimmed in the Place dialog box, but you will still be able to select it and place it in the new Illustrator file.
  1. In Illustrator, choose File > New.
  2. Select the appropriate size and color mode, and then click OK.
  3. Choose File > Place.
  4. In the Place dialog box, choose All Formats from the Files of Type pop-up menu (Windows) or choose All Documents from the Show pop-up menu (Mac OS), choose the damaged file, and then click Place.
  5. Name and save the file.
How to recover corrupted ai file of Adobe Illustrator
Feb 14, 2018 | Adobe Computers & Internet
View content of Illustrator?
Download and test third-part software for recovery illustrator documents like a Illustrator Recovery Toolbox from https://www.oemailrecovery.com/illustrator_recovery.html
Please follow instructions if you if you want to try to recover the file itself. :
1. Check a size of file. If it smaller then 50K then projects are empty
2. Attempt to re-create files as describe here: http://helpx.adobe.com/illustrator/kb/troubleshoot-damaged-illustrator-files.html
Sep 11, 2016 | Adobe Computers & Internet
Illustrator Error
Use Illustrator On-line repair service service will analyze the contents of your file, the internal data structure of the *.ai file in an online mode using a combination of intelligent algorithms. It will then provide you with a preview of recoverable project data. The service features a very clean an intuitive interface, which makes corrupt Illustrator file recovery a snap even for novices.
For more: https://onlinefilerepair.com/en/illustrator-repair-online.html
Nov 27, 2015 | Adobe Illustrator 10.0 for PC
How to repair illustrator file?
And also u can use the same program Illustrator Repair Toolbox
But with working link below:)
http://www.illustrator.repairtoolbox.com/
Dec 15, 2014 | Adobe Illustrator CS3 - Windows for PC...
Saved illustrator 10 file gets corrupted
Check for a damaged pattern, gradient, or custom color
To determine if the problem is caused by a damaged pattern, gradient, or custom color:
1. Choose Edit > Select All and change the fill and stroke to process black.
2. Perform task 4 again to determine whether the problem occurs in a new file that does not contain the patterns, gradients, or spot colors. If the problem does not recur, re-create the pattern, gradient, or spot color in the original file.
Otherwise:
First option: http://www.filerepairforum.com/forum/adobe/adobe-aa/illustrator/383-%E2%80%8Bcorrupted-fonts-in-illustrator-file-urgent-help-need
Second: shareware tool Illustrator Repair Kit
See more about:- http://www.illustrator.repair/
Oct 27, 2014 | Adobe Illustrator 10.0 for PC
How to add wallpaper to flash drive background?
First you need to create a desktop.ini file in your flash drive.
Open Notepad and click Save as.
Then set file name to desktop.ini and change Save as type to All files.
Click Save as.
Place your wallpaper in the flash drive. It should be a ".jpg" file
Open desktop.ini file from your flash drive. Copy and paste below code to it.
Last line of the code, you can see "IconArea_Image=wallpaper.jpg". Replace "wallpaper.jpg" with your wallpaper name.
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
Save your file. Unplugged the flash drive from PC and plug it again. That's it.
If you need more information
Visit SmartUSB.net
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Change your flash drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
Jul 25, 2012 | Electronics - Others
Technical details and dealer in kerala ( Cochin )
Technical Details
  • Brand Name: Coby
  • Model: MP300-1GBLK
  • Digital Storage Capacity: 1 GB
  • Color Name: black
  • Battery Average Life: 8 Hours
  • Supported Audio Format: MP3 // WMA
  • Display: LCD
  • Hardware Platform: PC
  • Width: 3.6 inches
  • Depth: 0.7 inches
  • Weight: 0.2 pounds
Product Features
  • MP3 player with LCD 1 GB flash memory and USB drive
  • high-contrast LCD display with 7-color backlight
  • plays MP3 and WMA digital music files, ID3 tag support for song information display, mobile data storage function
  • convenient integrated USB plug( no cables required)
  • USB 2.0 hi-speed for fast file transfers
Product Description Coby MP300-1GBLK MP3 player 1 GB flash memory and USB drive with LCD, high-contrast LCD display with 7-color backlight, plays MP3 and WMA digital music files, ID3 tag support for song information display, mobile data storage function, convenient integrated USB plug( no cables required), USB 2.0 hi-speed for fast file transfers, black.
Batteries: 1 AAA batteries required.
Feb 02, 2011 | Coby MP300 MP3 Player
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
Macromedia Flash MX Logo
158 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Tony
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
