Question about Sony KDL46EX520 46 inch BRAVIA 1080p LED LCD HDTV
Sony KDL46EX520 8 blinks - Sony KDL46EX520 46 inch BRAVIA 1080p LED LCD HDTV
SONY KP-61HS20 DOESN'T COME ON JUST BLINK 6 TIMES PAUSE AND 6 TIMES AGAIN
Sis blinks of standby light denotes No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. If you wish to get more details about blinking codes to Sony PTV, check this link.
Mar 03, 2013 | Sony KP-57HW40 57" Rear Projection...
My sony trinitron screen goes black and the standby light blinks
How many times the standby light blinks at a time? Number of blinking of standby light with Sony Trinitron CTVs are fault indications. To know more about these blinks, and fault location, get in this site named Electro-help, and pull up older posts there. Try this link, and select the site.
Jul 11, 2012 | Sony Televison & Video
I have a sony 50". in the power button, a red
i have a sony 57". in the power button, a red blinking light blinks 11 times.
KDP57W5655
Nov 28, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony KP-65XBR10W had blinking light
In your google toolbar type in Understanding Sony Blinking codes it will then take you to website that tells you what the blinks mean .
Sep 24, 2009 | Sony KP-65XBR10W 65" Rear Projection...
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
SONY KV35S40 Light blinks continuously when power is pressed
hello there,
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again.
May 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Grand WEGA KF-50WE610 LED blinks 4 times
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
May 21, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony tv kv24ls35u 11 blinks
Sony does not have 11 blink code it only goes to 10 blinks. You can Try self-Diagnostic mode- Press---- display,5,vol- then power when set comes up it should have codes telling you which circuit has problem.
Jan 03, 2009 | Sony KP43T75GRAY 43" Rear Projection...
Sony TV
Blinking what - how many times before it pauses and then blinks the next set?? Sonys have an error code of blinking to help isolate the problem... (count the number of times it blinks before pausing and let me know).
Bill
Dec 12, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KDL46EX520 46 inch BRAVIA 1080p LED LCD HDTV Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
